BIKELAND > FORUMS > ZX12R ZONE.com > Thread: starter and seat problem NEW TOPIC NEW POLL POST REPLY
iflyguns
posted May 27, 2002 06:03 PM
Hey guys need some advice. When I try to start my 01 12 the starter turns very slowly like the battery is almost dead. It does this more when the bike is hot or I'm giving it some throttle while trying to start it. I have heard there is a relay problem. What do you think?
Also,
My front seat has a a place just infront of my crouch right behind my tank cover where it has collapsed anyone else had this problem. I'm thinking it should be under warranty.
Thanx,
TD
Tony D
iflyguns
posted May 28, 2002 02:20 AM
Tony D
kawair
posted May 28, 2002 05:46 AM
My 1270 12 also does the starter thing once in awhile. It does seem to happen when the bikes fully warmed up and then shut down for a little while. It could very likely be the relay getting hot. I had an old Trans Am with a built big block that always did this when starting hot, and it was the relay soaking heat from the close header pipe.
hott-rodd
posted May 29, 2002 09:29 AM
top
beansbaxter
posted May 29, 2002 10:29 AM
Are these problems also with the 2002 models of the 12, or has Kawasaki addressed them already?
To answer your question though, your warranty will cover that. My dealership is awesome when it comes to warranty work.
sleezyrider
Mean Motor Scooter
posted May 31, 2002 07:12 AM
Hey Iflyguns... does your bike have a PCIIIR on it???
posted May 31, 2002 07:23 AM
Iflyguns,
I've tried to return your call but your cell doesn't answer. You must be flyin' a lot.
Doug
iflyguns
posted May 31, 2002 09:42 AM
Yes it does sleezy
Doug thanks I will call you back
Tony D
sleezyrider
Mean Motor Scooter
posted May 31, 2002 10:19 AM        Edited By: sleezyrider on 31 May 2002 14:13
It really makes me wonder
The reason I ask the PC111R question is I have experienced the same problem with my 12. In fact it was so bad I just knew my battery was bad and I decided to take it in for warranty replacement... Well, when I got to the dealer the battery checked out fine but the mechanic said it acted like the timing was extremely advanced. My response was I had a PC111R but had not entered any timing changes and it should be stock. So just on a hunch we disconnected the PC111R and the puppy fired up with no hesitation at all.
I ended up talking at length with the folks at DJ, but their response was this was the first time they had seen this type of problem. But I wonder if this is just the politically correct response when working for them.
The bottom line is that I would bet there is a direct link between the PC111R and the starting problems.
I still have this issue when starting the bike especially when it is fully warmed up.
So, just to make you feel better you are not alone with this problem.. I recently discussed this with my local DJ Tuning Center and they made the statement they have seen 4 or 5 12's with this same type of issue, and they all had PC111R's..
Take your PC111R off and see if the problem goes away..Then post what you find..
kawair
posted May 31, 2002 10:43 AM
Doug, do you have any feedback on this ?
posted May 31, 2002 02:18 PM
We've never experienced it, this is the first I've heard of it. I suppose it is certainly possible that the PC could play a role, but I'd have to have one of the computer geeks explain that to me.
Doug
0.23839092254639 seconds processing time
