BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Carillo rod bolts NEW TOPIC NEW POLL POST REPLY
ZX12-5807
posted November 24, 2006 09:10 AM
Carillo rod bolts
Can anybody tell me what the torque spec. or stretch is for installing a new set of carillos in a zx12r?
2001 ZX12 1287cc
2001 ZX12 1317cc Lee's head
TRNorBRN6001
posted November 24, 2006 10:44 AM
Check there site as they have a specific stretch for thier bolt, or just call them up they are real nice folk. I think max torque is 45 ft/lbs, but they go by stretch more than torque. I do not know for sure, but I think the A-beams have different bolts than the H-Beams which have the sps mutiphase ones.
TFA 200MPH CLUB MEMBER!
ZX12-5807
posted November 24, 2006 05:16 PM
Thanks, I will give them a call. By the way I have the H-Beam rods.
muleskinner
posted November 24, 2006 08:38 PM        Edited By: muleskinner on 24 Nov 2006 20:39
ROD BOLTS
If you are installing new rod bolts of any kind you should put them in the rod first, then while holding the assembled rod in a rod fixture, (or a soft jawed vice) you need to torque the bolts to spec for streatch. The rod big end should then be resized before using the rod in the engine. This is the right way to do it, although I know of some who just reuse the rod without resizing it.
posted November 25, 2006 04:21 PM
.005-7" stretch, not to exceed 45#. Mine generally run 35#.
Mule,
I agree about re-sizing when/IF the rod big end gets oval. If not, why re-size?
ninja12
posted November 27, 2006 10:54 AM
My turn.
Karl, Are there any parts made for or that will fit on the zx12 that you don't have?
G,
posted November 27, 2006 09:14 PM
G.
My ever-suffering heap is my "Senior science fair Project" and does get some attention
BTW: I thanks you much for the loan of the stock arm. It is newly painted (OEM gray), greased, and ready for return to you. Turns out it was a bit short for the Mile, and i had big wheelie probs, next time i'll go extended.
When I get back to Texas, I'll send it back, Thanks, amigo!
Karl
muleskinner
posted November 29, 2006 02:54 PM
Mule,
Resizing , or at least checking, when ever you replace the rod bolts is a good idea. Most rods wil be okay, but it's always a good idea to check them when you have the engine apart. It's just good cheap insurance. Rods tend to streatch and distort a bit under use, Etc.
0.21625995635986 seconds processing time
