BIKELAND > FORUMS > ZX12R ZONE.com > Thread: higher capacity injectors (again) NEW TOPIC NEW POLL POST REPLY
posted November 19, 2006 11:32 AM
Supra (i think) posted some time ago that 04-05 injectors are rated at 370+/-cc/min compared with 00's which seem to range from 310-330.
Anyone actually mounted a set of 04-05's on a 00/01????
I have a set of 375's from RC, but they are gonna be a royal PITA to make work.
My 1427 developed a weird drop in hp which has me pulling my hair out and i wanna eliminate fuel delivery issues as a possible cause. I just sent my OEM injectors off to RC for cleaning but also wanna investigate higher capacity ones.
supra5677
posted November 19, 2006 03:08 PM
someone on the board measured the 04-05 zx12r injectors at 380-390cc per minute depending on how
clean the injectors were. The stock injectors DO NOT flow enough to support a 1427 motor. You can get a stock set of 04-05 injectors for 80 to 100 bucks from 5-0. On the A models the fuel pump is not as strong as the b model. You might as well upgrade the fuel pump with that monster 1427 motor.
posted November 19, 2006 04:02 PM
Supra,
i have a Muzzy pump so OK there.
In the past my 1427 has produced up to 229hp with the stck injectors on Nutec sp5+ and 15:1 CR. Great dyno hp but real poor track longevity (detonation or pre-ignition, i can never remember which is which).
Maybe my stock injectors were on the edge and slipped over???
Do you know if the 04-05 injectors will fit in a 00??
shane661
posted November 19, 2006 04:40 PM
I also would like to know whether they fit an '02...(for a bigger dry shot)
supra5677
posted November 19, 2006 04:59 PM
I dont see why they would change the injector rail. ask 5-0 he
defenetely knows...
posted November 19, 2006 09:53 PM
Why a PITA, Karl? The RC 550's that Rob sells go right in with a small spacer (which he supplies, I think). You just lose some frame clearance on the rail. I've been using them for years. The stock injectors are really flakey over 200 hp. If you are still running the same ones they're probably taoast by now. Flow is mush more stable with big ones.
D.
posted November 20, 2006 12:33 AM
Doug,
PITA because the injector length puts the rail right against the airbox, and getting the TB's onto the motor is problematic (for me).
Now that I have the motor out, I suppose that i can mount the injectors/TB's before rotating the motor up and securing the top rear motor mount.
If the rail is against the airbox will the vibration bother the fuel delivery???
psycho1122
posted November 20, 2006 08:20 AM
Using them for years now?? Ok, sounds interesting!
Why did you go with the "550's"? I would suspect they would operate at a reduced "Duty Cycle".
feedback on entropy's question will come in handy also.....Thanks!
aliveagain
posted November 20, 2006 12:47 PM
Are the 12 injectors high or low impedance?
TRNorBRN6001
posted November 21, 2006 09:01 AM
Just curious what kind of a duty cycle are your injectors running with that monster 1427?
Also curious on the price of those fatty 550's?
Ya might want to switch back to the Hans for the Big Dyno Numbers!!!!!..........Just Kidding ya.
TFA 200MPH CLUB MEMBER!
posted November 21, 2006 07:51 PM
Yes, brings the duty cycle down to the point the the injector is actually having some "resting" time. They stay cooler last longer and the fuel qty is more stable.
No sign af any problems with the rail on the frame. I reckon the fuel under 55+psi pressure isn't going to "foam" is it?
Did the same thing on my Corvette- went from the stock 26 lb/hr to the Ford SVO 32 lb/hr injectors. Mush easier to tune.
D.
Y2KZX12R
CompetitionCNC.com
posted November 22, 2006 03:23 AM
Doug, I'm running the Lucas/delphi 42# injectors (disc type) and found the slow speed metering and driveability better than the SVO pintle style.
Do you use HpTuners software for the Vette?
Y2KZX12R
CompetitionCNC.com
shane661
posted November 22, 2006 03:47 AM
Running big injectors/fuel pump would allow a larger dry shot of nitrous, correct? I have heard of some resistor mod for this. Would that even been needed with a properly tuned big injector setup?
psycho1122
posted November 22, 2006 05:52 AM
Hey Doug, It looks to me like your target was in the 50% Duty Cycle range...Correct?
posted November 22, 2006 06:26 AM
i am told that going too low on the hi end, makes tuning on the low end problematic.
any truth??
Megabyte
posted November 22, 2006 09:05 AM        Edited By: Megabyte on 22 Nov 2006 09:18
Where do you get the larger injectors, 550 etc web site, phone, email?
Thanks,
psycho1122
posted November 22, 2006 05:47 PM
RC Engineering
http://www.rceng.com/
Megabyte
posted November 23, 2006 09:07 AM
RC Engineering
Thanks for the URL. Which RESISTANCE High Approx. 12 - 16 OHMS or
LOW RESISTANCE - 2.5 / 3 OHMS
Happy Thanksgiving!
0.22825407981873 seconds processing time
