BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Need help with DynoJet map 02 NEW TOPIC NEW POLL POST REPLY
ozion787
posted November 06, 2006 08:06 PM        Edited By: ozion787 on 6 Nov 2006 20:09
I have an 02 12 -- Full Yoshi exhaust K&N filter with modified air box and power commander III usb. I just installed the map recommended by powercommander.com for this setup The reason why Im looking for a different map is because of my airbox modification, is the map from dynojet enough or is there one out there for a airbox upgrade?
Thanks in advance for any suggestions
zxlnt
posted November 06, 2006 09:18 PM
What do you mean modified airbox?
ozion787
posted November 07, 2006 04:17 AM
Re-aranged air hoses removed valve air switch. This eliminates hot air from the motor to be recycled back in.
Texas12R
posted November 09, 2006 03:18 PM        Edited By: Texas12R on 9 Nov 2006 15:22
I reserve the right to be wrong....I posted a question some time ago with regards to tuners
and a/f ratio on a basicly stock 12.....Mr Hill suggested using a pc3, and Mr Myer also suggest the same....The thing to remember is the factory map is pretty good from what I saw on my base dyno run, but there is room for improvement. The factory gave us a "one size fits all" map and it does the job. If you are looking for more power It is my opinion that you will need to work on a map for YOUR bike....every engine is different and until you actualy see where the a/f ratio is everything is just speculation... I think like others have posted
that the factory map is rich and that is far better than being lean.. I know we dont race dynos
but its better than a seat of the pants guess at how much power you are making....so go to a tuning center and run a baseline so you have the data that points out the a/f ratio and where it could be improved......
shane661
posted November 09, 2006 03:29 PM
I am not sure that the kleen removal changes the mapping?
12r1
posted November 09, 2006 03:35 PM
I eBay'd my Yosh, from my '02, after trying every map I could find....ran terrible. Lot's of you use the Yosh, so it must just be my particular '02 12R?
Runs strong with the 'ol stock bazoooka on there!
0.20821404457092 seconds processing time
