BIKELAND > FORUMS > ZX12R ZONE.com > Thread: steering shake NEW TOPIC NEW POLL POST REPLY
wilson1
posted May 10, 2002 04:50 PM
steering shake
a friend of mine has bad steering shake at about 50 MPH i went to tourque stem bearings and the nut was very lose i tourque them to spec 14.5 foot lbs still had shake i retourque to 20 foot lbs it was better but still had shake iam thinking because bearings were so lose that races are bad any thoughts ¿¿
BFLY
posted May 10, 2002 05:06 PM
check wheels brakes and any nuts bolts for front end.
check front tire for bubbles ect. if none of that pull top of tree and check race'sa
  Ignore this member    Click here to send BFLY an AIM message.
posted May 10, 2002 06:36 PM
Listen... I had this on my 12.. drove me fucking NUTS all last season.. no matter WHAT I did to adjust the bearings (which were TOTALLY loose BTW) nothing solved the shake.... my 12 just had it's 10K service... what this involves specifically re: forks I do not know, however it is my understanding that they take them apart and also change the fluid in them etc....
Shake is now GONE.... bike is soo stable.. rides like a different machine... I believe it was swft who suggested that the shake may be due to unequal volumes of fork fluid...
posted May 10, 2002 07:49 PM
I wish I could take credit for that, but I don't recall that! I may have suggested looking at the forks, because of the great difference having them rebuilt has made for me.
Ninjaman12R
as a Deal's Gap tour guide.
posted May 11, 2002 05:37 AM
Forks....
Even though my bike wasn't doing any shaking I can safely say that having the forks reworked on the 12 was a good move. It's a different machine in the twisties.
GMD Computrack reworked mine and put heavier springs in them, Circuit One compression pistons, and a custom revalve. All I can say is that it was worth the $$$$$$. I have more adjustability now than I ever had with the stock stuff.
posted May 11, 2002 06:27 AM
Hmmm... if it wasnt swft then it was someone else!
ZHooligan
Post Whore Extraordinaire!
posted May 12, 2002 11:07 PM
Sometimes it is as simple as the fork tubes are not straight in the triple clamps. You might try to losen up the triple clamp bolts and spin the front tire and then snap on the front brake. Do this a couple of times.
Also are your fork tubes set at the stock height? If they have been raised significantly you will definitly experience head shake!
future; -- Youth is forever.
iflyguns
posted May 13, 2002 05:17 AM        Edited By: iflyguns on 13 May 2002 06:22
Check your rear wheel alignment if it is adjusted more on oneside than the other this will happen.
TD
Tony D
0.2283730506897 seconds processing time
