BIKELAND > FORUMS > ZX12R ZONE.com > Thread: wheelie Bar ? NEW TOPIC NEW POLL POST REPLY
Diverig
posted May 04, 2002 09:30 PM
wheelie Bar ?
Just a question or two
who makes a set for the 12?
And how hard are they to get use to?
Dose the frount of the bike have to be straped down?
zxlnt
posted May 04, 2002 11:01 PM
Pingel makes wheelie bars for the 12R. U will need to get an M/T MCR2 at the very very least and more than likely a full racing slick. Gear the hell out of the bike so you can just dump the clutch completely off the line without it bogging. U will for sure want the Muzzy clutch kit and Falicon basket. It not just a simple thing to bolt on a set of bars and go fast. Ya have to have the whole package. What mods have you done to your bike so far?
Cowboy
posted May 05, 2002 05:27 AM
Exactly
posted May 05, 2002 03:23 PM
Hey cowboy! I've got the slick coming, going up two on the rear, and down one on the front. That enuff gearing?
Cowboy
posted May 05, 2002 04:29 PM        Edited By: Cowboy on 5 May 2002 17:30
Swft
Swft,that should be good place to start with your torque and the lockup.Remember,Start with no weights like MadMike suggested and find the right rpm to leave at so it doesn't bog or blow the tire off.Then to fine tune the gearing you want to finish at the top of a gear and i would think 5th with your setup.Probably about 12lbs in that slick with a big guy like you on it.I wish I could be around when you were trying it out.
Diverig
posted May 05, 2002 05:03 PM
Thanks guys for right now I'm just colecting info on what I need to out fit the bike for drag racing.
I've raced some smaller size bikes in the low 13 sec
and a 1969 Mustang to low 11 sec sold everything and got out of racing but now after owning the ZX12R I might get back in.
Cowboy
posted May 05, 2002 07:04 PM
Were you thinking of still riding your bike on the street or just the track?I ask because a street tire and wheelie bars with strut will work on most sportbikes just fine but the busa and 12 have too much power and the street tire, even after mid track, will try to buck you off looking for traction.You might get away with the shootout tire but then your not going to be out carving any corners.
posted May 06, 2002 05:38 AM
I still think it was funny when I broke loose right off the line and *cleaned* the concrete pad off!
hotrodninja
posted May 06, 2002 06:08 AM
Front end straps with wheelie bars are not legal in the NHRA rule book, and believe that's the norm. With good reason. You have virtually no suspension, and the bike could be a handfull.
Be consistent, win money.
posted May 06, 2002 03:26 PM
I guess if I was running a NHRA bike, that would matter. Or had a NHRA license. Seriously, that's on the horizon. If I get where I can run 9 secs, I want to be *able* to run 9 secs, ya know?
Cowboy
posted May 06, 2002 08:52 PM
Swft,if you run at a nhra track then it is nhra bike rules.
posted May 06, 2002 09:10 PM
Ah, thanks for the clarification!
kcadby
posted May 07, 2002 06:58 PM        Edited By: kcadby on 7 May 2002 20:00
strap???
I think it would be better to run bars without the strap anyway because...you WANT the weight to transfer to the rear but...you don't want too much travel so...turn the front springs in to raise the front end
Also...I know your tall (swft) so...sit towards the rear of the seat since there is no wheelieing to worry about with the bars...get that poundage ON THE REAR TIRE
0.22810697555542 seconds processing time
