BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Stripping/Polishing stock wheels NEW TOPIC NEW POLL POST REPLY
magzx12r
posted May 01, 2002 02:14 PM
When stripping the paint off of the wheels, how do you get the paint off between the lip of the rim and the tire? If I put some of the aircraft stripper in this area and it set on the tire, would that cause any problems with the rubber?
Also, what type of polish is best for polishing the wheels after the paint is stripped? I used some "never dull" and it worked o.k.
Mark
'03 ZX-12R
'12 1199S
Your Car Is Slow
Fuck Nitrous...Got Boost?
posted May 01, 2002 03:02 PM
Take the tire off the rim if possible...makes it much easier
Use Mothers aluminum polish after stripped.
Do not taunt happy fun ball!
BlackMandingoWarrior
posted May 01, 2002 08:31 PM        Edited By: BlackMandingoWarrior on 1 May 2002 22:42
Use Strips Of Cardboard
Let the air out of the tires and wedge strips of cardboard between the rim and tire.
Use the aircraft stripper generously. I used a small wire brush to scrub off the loose soft paint. Blue Magic aluminum polish works well also and leaves a silicone protectant too. These are the results.
BMW
The QuickSilver Ridin MoFo
Rocket J
Goes to water over a dummy!!!
posted May 01, 2002 08:41 PM
Just curious...
Anybody chrome plate as opposed to polishing?
Rocket
If I get any smarter, my head will explode!
posted May 01, 2002 08:59 PM
These Are Chromed...
Along with the swingarm. I've heard where you can get both rims chromed for $500.
BMW
Rocket J
posted May 01, 2002 09:46 PM        Edited By: Rocket J on 2 May 2002 22:52
Any excuse for you to trudge out that picture of you and that girl!
$500? Do tell, BMW.
Rocket
zx11_12
posted May 02, 2002 02:50 AM        Edited By: zx11_12 on 4 May 2002 06:52
An easier way
The way mine were done was to put the bike on a stand, put an electric motor under the tire to spin the wheel and just hold progressively finer grades of wet/dry sandpaper agaist the wheel as it spins. This way the wheel does all the work for you. It took one evening to polish both wheels and you can even get the sandpaper far enough into the crack between the tire and wheel that you can't see any paint left in there either. Just a suggestion. It worked for me.
Steve
"There is only one basic human right, the right to do as you damn well please. And with it comes the only basic human duty, the duty to take the consequences."
PJ O'Rourke
  Ignore this member    Click here to visit ZX11_12's homepage. Click here to send ZX11_12 an AIM message.
Wildman
I only look confused
posted May 03, 2002 10:08 PM
I had the tires removed to do mine.
Use the stripper, just be sure to use GOOD rubber gloves and be careful where you get the stripper.
With the tires and discs off the wheels, it was easy to do a clean job of stripping, polishing, and painting them.
I don't have a hosting site right now so I can't post the pics of my wheels.
If you build something Idiot Proof, The world will build a better Idiot.
VINCE12
Designated Drinker.
posted May 04, 2002 03:30 AM        Edited By: VINCE12 on 4 May 2002 04:34
Worth the extra cash to have the tires removed!!!!
2012 Metallic Spark Black ZX14R
Scooter
posted May 04, 2002 03:30 AM        Edited By: Scooter on 4 May 2002 04:30
Keep it above 70 degrees and the stripper works best. Below 70, not so good. I used a small modeling brush to get the fine lines. The stuff takes 15 - 20 minutes to work so if you slop a bit in the wrong place there is plenty time to wipe it off. Used the pointy wooden end of the brush to get inbetween the tire and rim. FWIW.
Dad working on his rims. http://community.webshots.com/rz/r1/5/21/17/19852117dTJxiSETXL_ph.jpg
http://community.webshots.com/rz/r1/5/21/31/19852131zrVtuqKXXh_ph.jpg
Donehttp://community.webshots.com/rz/r1/5/21/84/19852184tvqetzoYvW_ph.jpg
"Growing old is inevitable, growing up is optional."
  Ignore this member    Click here to visit Scooter's homepage.
posted May 04, 2002 05:00 AM
and do it in a well ventalated area,, dude I was goofy for a week!! even with the vented area the second rim made me feel weird... but it was alot better, and good!!! gloves is correct, I had a heavy pair with cotton backs and they worked ok, I would get all rubber... gotsome on the back of mine and things got hot real quick.. But it is worth it...
Mad Mike
magzx12r
posted May 04, 2002 07:50 PM
Thanks for all the tips. I did mine with the wheels on. There is still a little paint between the rim and the tire, but you can't see it unless you are real close to my bike. Overall, the wheels look good. That stuff does burn, I got a little spec on my arm and it started burning. Glad I had some water around to rinse it off.
Mark
'03 ZX-12R
'12 1199S
0.28233003616333 seconds processing time
