BIKELAND > FORUMS > ZX12R ZONE.com > Thread: FIX FOR ZX14 Track-SUPERTuned Handling NEW TOPIC NEW POLL POST REPLY
ZX14TR
posted August 16, 2006 04:04 AM
MUST BE outfitted with adjustable steering damper BY Öhlins & Rear Suspension:Öhlins with Adjustable Preload, Stepless
Rebound and Compression Damping, Ride Height Front Suspension: Öhlins 43mm Inverted Cartridge Fork with Adjustable Öhlins
Preload, Stepless Öhlins Rebound and Compression Damping Öhlins springs coupled with a racing-spec Öhlins steering damper & a Hydraulically operated back-torque limiting clutch(KP) automatically disengages the clutch under hard braking and deceleration to prevent rear wheel hop during corner entry.features a radial mount clutch master cylinder for worry-free, super silky smooth clutch operation. Optional springs, spring retainers and shims are available to fine-tune the clutch for specific conditions, featuring a radial mount clutch master cylinder for worry-free, silky smooth clutch operation.NOW FIXED
This most powerful of all Kawasaki-branded motorcycles IS NOW created to do everything right. Right from the beginning.WITH THIS FIX! TURN YOUR OLD ZX14 INTO A NEW ZX14R
0.28474092483521 seconds processing time
