BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Is anyone using a steering damper??.... NEW TOPIC NEW POLL POST REPLY
droid
posted May 20, 2006 03:46 PM        Edited By: droid on 20 May 2006 16:46
.....If so which one and how do you rate it?
blitzkrieg
Road kill = Free lunch.
posted May 20, 2006 07:20 PM
Yes. On my 12 I have a Scotts/Ohlins.
Nice unit and expensive. You get what you pay for.
The R1 has the factory installed lateral damper I haven't put the bike through the pace's enough yet to comment on how well it works.
vozizm
Got Nothing Witty To Say
posted May 20, 2006 07:45 PM
i have an 02 so Muzzy is the best choice
VOZ
harryzx-12
posted May 21, 2006 12:22 AM
Scotts/I like it.
Y2KZX12R
CompetitionCNC.com
posted May 21, 2006 04:08 AM
Muzzys damper here. Expensive, has some flex in the mount, but havent had any trouble with it.
I got it in a group purchase on here in 2000 that made it more reasonably priced. Otherwise I was leaning towards a scotts. Never had a scotts and wanted to try one.
megabyte
posted May 21, 2006 08:14 PM
Scott's on my 2k 12, but it's a PITA to install. Do you have thin arms and small hands?
droid
posted May 22, 2006 06:35 AM
Quite frankly not to sure about drilling my frame!!
Ninjaman12R
as a Deal's Gap tour guide.
posted May 23, 2006 10:45 AM
scotts on my '00
That's a not an issue if you tap the frame. D
I did mine that way over 5 years ago and it has held up beautifully. I did go up one size with the bolts to an 8mm I think. I had to drill out the holes on the damper bracket to accomodate the larger bolts. That took all of 2 minutes. I torqued the bolts pretty tight, and used thread locker as well. No way my arm would even think about fitting up in the frame. I honestly don't know why they didn't design the thing to be mounted this way in the first place. It seems like the obvious choice to me. I mean you have to drill 2 holes in the frame either way. Anyone should be able to tap a couple holes.
The damper was a wise purchase as I love to wheelie my bike, and generally flog the piss out of it. All of which brought the occasional headshake, which I don't like. Anyone that tells you their bike has never had any headshake is either lying, or they have on lace underwear and don't ride hard enough. I've even heard dumbasses say that a properly set-up bike doesn't need a damper. What a load or horseshit!!!!!!!!!!!!!
blitzkrieg
posted May 23, 2006 04:21 PM
Amen brother.
I had to get really creative with the install..
The way the inspection cover is situated and where the lock nuts have to go it's virtually impossible to reach if you have long forearms.
I came up with a trick using a short (2 ft.) length of garage door cable (open at one end, terminated at the other), carefully placed 2 part expoxy between the lock nuts and washer and air box and then fished them them through the install holes and let them set up.
After that you can carefully install the mounting bolts (lock-tited) using a 1/4 socket on the bolts with a really long swivel extension, but the whole process is real close to surgey.
Once installed you'll be happy but its not for the ham fisted or impatient.
droid
posted May 23, 2006 04:33 PM
So how about drilling the frame and heli-coiling then, would that suffice?
Not sure that i fancy its IN YOUR FACE fitment, could be taken literally, does anyone make a less intrusive damper.
I appreciate the frame is probably the stumbling point for a tucked away fitment.
Anyone used/using the hyper pro set up?? Thoughts /issues
posted May 23, 2006 08:55 PM
I have a Scott's also and I love it...
I just had my wife hold the nuts and I tightened it...
Mad Mike
Ninjaman12R
posted May 24, 2006 04:30 AM
Dude, read my post above. No need for heli-coils at all.
0.29726600646973 seconds processing time
