BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Fuel Injector Flow Rate NEW TOPIC NEW POLL POST REPLY
TRNorBRN6001
posted April 25, 2006 12:39 PM
Dang, I knew I should have sent my injectors under Entropy's Name!!!!!!
Just Got my little weak stick injectors back from RC cleaning and flow test.
Bike has around 17K Miles on it.
Before Cleaning 312, 299, 314, 308 cc/min
After Cleaning 320, 318, 321, 320 cc/min
I think Entropy's were all around 330 -331 cc/min. I might have to
get a sewing needle out and poke at them a little!!!!
Anybody have similar results as mine? or anyone else have them cleaned
and flow tested?
TFA 200MPH CLUB MEMBER!
psycho1122
posted April 25, 2006 02:40 PM
I own TWO sets of injectors from stock 2000 12R's.
One set is a 320cc set and the other is a 330cc set.
Yours are fine, go ahead and use them. You are talking about a 3% difference over a minutes time. 10 whole cc's in a minute is not that much.
TRNorBRN6001
posted April 26, 2006 05:46 AM
Yeah, but it'd be nice to have a little extra so them poor fellas don't have
to work so hard over that minute, ha, ha, ha.
Just curious what is the stock 12 fuel system max'd out at? 220HP-240HP?
psycho1122
posted April 26, 2006 07:24 AM
200-204 h.p. That's on the Edge!!
your car is slow
Fuck Nitrous...Got Boost?
posted April 26, 2006 07:44 AM
eh.....id say the "edge" is far higher than 200hp.
psycho1122
posted April 26, 2006 08:55 PM
with the stock fuel pump it is!
your car is slow
posted April 27, 2006 06:25 AM
I disagree...if it were...id have lunched my motor years ago...but id rather not start yet another thread about the 12s fuel system.
posted April 27, 2006 07:05 AM
How much was that??? I want to have that done also...
MM
TRNorBRN6001
posted April 27, 2006 07:39 AM
RC Engineering
20807 Higgins Court
Torrance, CA 90501
(310) 320-2277
$24.00 each
I just figured since the bike was apart I might as well make sure the injectors
were up to par and not all clogged up. I'd hate to have put them in and then have
a lean condition, especially if it were only in one cylinder.
I also picked up a Muzzy fuel pump to be on the safe side, but I think I'll be under
200-204HP.
Your Car Slow what kind of numbers does that 12 of yours put out?
your car is slow
posted April 27, 2006 09:29 AM
before the muzzy pump....i was making nearly 250rw on spray....and I went through a TON of bottles...ran it for over a year on that setup.
Had a wideband hooked up to the bike...a/f was well under 12:1 at wot on spray while riding. had it dynoed a bunch of times as well and as expected...was even richer there.
All that on the stock injectors/fuel pump/pressure/whatever...if 200 was the limit...there is no way Id have been able to deliver fuel to that motor on spray and seen the numbers I did in terms of a/f.
muzzy pump and MUCH larger injectors are on it now though...but for a different reason.
psycho1122
posted April 28, 2006 06:15 AM
Of course it was rich if you were running a WET nitrous system.
your car is slow
posted April 28, 2006 06:53 AM        Edited By: your car is slow on 28 Apr 2006 07:54
ill give you another chance to guess what sort of nitrous system I was running as your first attempt was incorrect.
ninja12
posted April 28, 2006 06:59 AM
LOL,
i needed that!
0.38500380516052 seconds processing time
