BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Cam Sensor Oring NEW TOPIC NEW POLL POST REPLY
blubyu
posted April 19, 2006 06:01 PM
Cam Sensor Oring
I think I have an oil leak coming from my cam sensor. I read a thread a while ago stating that the o'ring goes bad sometimes. I can't locate a part number for it. Anyone know what size o'ring is on the sensor? I was thinking about running down to Home depot and grab a handful of various sizes.
Go-T
posted April 20, 2006 04:07 AM        Edited By: Go-T on 20 Apr 2006 05:10
Part number96055-1369 - I tried the similar but different o-ring deal. If it is any thicker than the stock one it is almost impossible to get the cam sensor back in. Put on the new oil ring put some grease around he o-ring and slid it back into position - put the retaining bold back in an VOILA - she's done - took about 15 minutes. I suppose it would not hurt to put some high heat silicone aroun the o - ring. May I suggest that you do not get any get any on the cam pick up side.
I used the stock part which I obtained from the 2005 parts fiche as it is not on the 2000/2001 fiche.
My girlfriend can't wrestle but you should see her box
0.21812701225281 seconds processing time
