BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Kleen Air Question....... NEW TOPIC NEW POLL POST REPLY
green monster
posted April 07, 2002 08:43 PM
When installing Muzzy Blockoffs you do leave the reed valve assembly in don't you?????? Thanxxxxxxx Guys......
ZXtra
posted April 08, 2002 12:18 AM
Yes, leave the reed valves in and be careful that the gaskets are in position. -ZXtra
zx12richard
The Green Monster..
posted April 08, 2002 08:28 AM
Thanxxxxxxxxxxxxx Thats what I thought.....
fastestr1
posted April 08, 2002 10:23 PM
I know this is an old subject but I just got an 02 and wanted to know what is the benifits of removing the KLEEN air system?
Black 02, 8.99 @ 161.95 motor on NOS
Put one knee down for the curves and both knees down for GOD
ZXtra
posted April 09, 2002 12:48 AM
Benefits?
The kleen air system allows fresh air from the air box to be sucked into the exhaust system through a rubber hose and a throttle body vacuum controlled valve.
The fresh air allows the fuel to burn more completely within the exhaust system (especially at the catalytic converter) to reduce exhaust emissions.
The parts that we horsepower freeks don't like are the extra heat produced and a slight increase in exhaust back pressure resulting from the combustion in the exhaust. Another negative is often after you add an aftermarket exhaust, you may get "popping" out the muffler which usually dissappears after removal of the kleen air system. -ZXtra
fastestr1
posted April 09, 2002 03:48 PM
So the popping comes on decel because the kleen air is opened when the throttle is closed or at idle. So where does the hp increase come from the decrease in heat?
ZXtra
posted April 10, 2002 12:50 AM
Theoretically if the kleen air is vacuum controlled, then you would expect it to work only at high manifold vacuums. Which means that when you open the throttle, it stops working, and supposedly doesn't cost you any horsepower.
But the kleen air supplies oxygen for the catalytic converter to work properly. So if you get rid of the cat, you don't need the kleen air. The exhaust will flow slightly better without the cat and we all know what a better flowing exhaust will give you.
I haven't actually seen dyno numbers for just a kleen air removal. Maybe someone else has checked...anyone?? -ZXtra
0.24360489845276 seconds processing time
