BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 20 tooth countershaft sprocket NEW TOPIC NEW POLL POST REPLY
harryzx-12
posted April 14, 2006 03:15 PM
Put a 20 tooth c'shaft sprocket on my 12 to do a little road trip. Wonder how much my milege will improve?
posted April 14, 2006 03:37 PM        Edited By: VincentHill on 15 Apr 2006 05:28
Harry, you got mail
Harry, It is pretty close with the 19'sGeared close to a 40 tooth rear or about 220 MPH is a very tall gear to pull away from the traffic Light or for Land SPeed Racing! That is why I bought a set of OD Gears for 5th & 6th which are about 4 teeth taller than stock so I can be short off the line up to 4 th gear and when spraying 5th & 6th it will pull them.
If you plan to tour Kansas no problem but any up or down hill and you will be a shifting fool. Actually you may use more fuel because of the increased throttle postion you will need to pull the gear. I would use a 19 because I was able to pull from the lights with a 47 rear sprocket. About 18 44 gearing! Did you get my message about the "0" RIngs?
Eric_The_Jew
posted April 14, 2006 06:28 PM        Edited By: Eric_The_Jew on 14 Apr 2006 19:29
The way you like to twist the throttle Harry, i'm sure it won't improve any! :P
Where are ya road trippin'?
harryzx-12
posted April 14, 2006 07:03 PM
Goin to dothan to spend easter with my daughter/grandaughter.
Vincent - it's mostly flat here. I rode it around town today with the 20 tooth and it seemed fine to me.
I'm not going to land sped race my 12 but i will my turbo busa. My ass will go over 200 mph. Something is bad wrong if i can't go over 200 with 573.8 hp!
0.23040890693665 seconds processing time
