BIKELAND > FORUMS > ZX12R ZONE.com > Thread: curing high temp paint NEW TOPIC NEW POLL POST REPLY
frEEk
posted April 05, 2006 04:00 PM
painting the side tanks on my radiator, using high temp paint. it says to let air dry 60 mins, then put in a non-household oven for 60 mins at 650F. What is the reason for using a non-household oven? If i do use one, am i gonna kill anyone that eats anything baked in that over after (even after lots of time and a good cleaning)? does it matter than my over only goes to 500F? it's an aluminium rad of course, so i'm kinda worried about getting that hot anyway. any experience and knowledge would be MUCH appreciated!
blitzkrieg
Road kill = Free lunch.
posted April 05, 2006 04:40 PM
The inorganic compounds embed themselves in the oven surface and when you make meatloaf or pizza impart themselves in your food. Once that happens its over.
I only know this because I wondered the same thing and did some digging a few years back.
frEEk
posted April 05, 2006 05:01 PM
hm, seems like a good scrub would cure that problem no? (i really hope someone answers yes cause i'm an idot and already did it)
blitzkrieg
posted April 05, 2006 05:52 PM
Not from what I read.
frEEk
posted April 05, 2006 10:05 PM
fuck, then i'm going oven shopping
flite leader
posted May 11, 2006 03:14 PM
reason being
highly explosive or combustible
result most are NOT actively vented
second reason most household ovens cant consistently hold 650f temps
i know of NO foods i would eat that need to be cooked
at those temps
bend your mind.....
or break your ass...!!
Droid
posted May 11, 2006 03:16 PM
"painting the side tanks on my radiator"
WHY??
pdb1964
posted May 11, 2006 04:21 PM
why did you use a "high temp" paint? Rad doesn't get that hot, does it? I guess next time you can take the part that has to be cured to a powder coating place. They have "non-household" ovens. Probably cost $$ though.
your car is slow
Fuck Nitrous...Got Boost?
posted May 11, 2006 04:28 PM
many people spray their brake calipers and surrounding areas with regular old high temp spraycan shit.
the radiator wont see anything upwards of 250 or so (if it does...who gives a shit about the paint at that point)
the spraycan shit is good to significantly higher than that.
frEEk
posted May 11, 2006 06:09 PM
yah, i only cured it at 425 or so. was about all the over could do. as a result (i assume) some of the paint has flaked already, where the survface was too smooth.
as to why, cause i got no fairings. looks much better with the black rad IMO
no, rad doesnt get that hot, but was concerned that regular paint may not hold well, and figured high temp paint would be less liekly to chip. could be that was very wrong tho. just used the cheap spray can shit mentioned above. wasnt about to invest in powder coating for this POS bike.
pdb1964
posted May 11, 2006 06:48 PM
what colour did you paint your rad?
Ya, paint can start to chip off a smooth surface. It is a good idea to scuff the surface by sanding first.
I'm pretty sure regular paing will hold up to the heat. I painted the engine side covers with regular paint and it is fine.
frEEk
posted May 11, 2006 09:42 PM
flat black, tryin to match the frame as best i can.
NOX
PMRA / TMRC Super Street 4022
posted May 13, 2006 07:15 PM
I used VHT high temp black gloss on my clutch cover and alt cover.....
baked it at 300 for an hour in the oven.......
I am the cook in the house, that was over a year ago,
I cook all the freakin time.............
We are all still alive here.............
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
Ozzy
need guberment cheese
posted May 14, 2006 05:04 AM        Edited By: Ozzy on 14 May 2006 06:06
what temp does the glue breakdown?
posted May 16, 2006 06:01 AM
650!????
What the hell kind of paint is that? I've baked all sorts of stuff in the kitchen, pistons, gears
transmission shafts, dash panels, etc.-using paint, moly coating, Crackle finish, etc. Never went more than 300F for an hour.
Usually pissed off the "woman du jour" is all. No funny growths yet.
Doug
frEEk
posted May 16, 2006 10:33 AM
high temp paint. were you just using regular paint doug?
mlb
posted May 16, 2006 07:55 PM
I'd say the biggst reason they say no household oven is that no household oven that I know of will get to 650.
0.23092699050903 seconds processing time
