BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Flasher problem (turn sigs not nekkidness) NEW TOPIC NEW POLL POST REPLY
WhiteLightning
posted March 29, 2002 01:26 PM
Alright all...
I need an elegant solution.
Being super cool (dumb?), I replaced a set of rear turn signals with super fancy LEDs. They are cool. BUT, they don't load up the flasher relay enough. They draw so little power and have such a high resistance its like they aren't there. Thus the relay thinks there are no/burnt bulbs and does the tripple time thing.
I have some ideas, none are elegant.
HELP!
WL
PS anyone going to NYC autoshow?
Road Dog
posted March 29, 2002 01:47 PM
You should be able to purchase another relay at any auto parts store and increase the resistance to slow the flashing down. Your dealer should be able to tell you how much current the stock lights were pulling and you could just wire the new one in line. This should not cost anymore than $5 to $10..
I hope this is helpful..
Road Dog
WhiteLightning
posted March 29, 2002 04:16 PM
RD-
Ok, how bout a bit more detail?
Cause I can load the circuit but not without burning some amps. (big resistors). I need to restudy my electronics.
WL
zxlnt
posted March 29, 2002 04:29 PM
YES abt 2 ohms wired in parallel will do it. Use at the very least 10 watt resistors and 20 watt would be better.
If u can find the gold aluminum heat sink type power resistors then that is the best.
Road Dog
posted March 29, 2002 04:35 PM
If I remember correctly the stock circuit is about 25 watts, so try to shoot as close as possible to this ...
psycho1122
posted March 31, 2002 06:35 AM
Solution!!
NAPA sells a "Load Sensing" flasher relay for @ $10.00
It is round, clear and fits nicely in the Batt. Box w/ a small mod to the plugs on wireing, your ready to go!!
zxlnt
posted April 04, 2002 05:51 PM
Part # for the relay?
ROCKET J
Goes to water over a dummy!!!
posted April 04, 2002 08:34 PM
Personally...
I think you are low on Blinker Fluid. The experts on this site agree with me.
http://kalecoauto.com/
Rocket
If I get any smarter, my head will explode!
fghjgf
posted April 05, 2002 02:07 PM
Read on if you care.
I have the same problem on my HD. Only more so with self canceling turn signals. I was told by a electrical engineer the most accurate way to solve the problem was to measure current flow at the flasher before and after the led install. Then calculate what size resistor is needed to bring the current flow back to normal.
starting current - ending current=x
Voltage / x = resistance
zxlnt
posted April 05, 2002 04:07 PM
Yep about 2 ohms should do it..
slug
Out in search of my mind...
posted April 05, 2002 05:32 PM
heh that kaleco site is awesome..i need a new kahneutson valve...
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
hondo
posted April 09, 2002 11:16 PM
Most HD dealers sell aftermarket equalizers designed to compensate for bulb changes.
0.33017206192017 seconds processing time
