BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Hans Snorkel Undisputed Test NEW TOPIC NEW POLL POST REPLY
supra5677
posted January 14, 2006 09:54 AM
Can somebody run a stock zx12r and do 5 top speed runs at maxton...Then bolt on the Hans Snorkel with no other changes and do 5 top speed runs within a 30 minute window of the first 5 runs..Make an average of all the runs and see which one comes out on top..
Fearsome K always seems to be in the minority but he sure does back his SHIT up!! Ever since I received my letter from Keith Parnell I'm sold on whatever he says...
supra
supra5677
posted January 14, 2006 11:38 AM
Question: How many cfm's do the 46mm throttle bodies flow? How many cfm's do the ram air intake runners flow? Is there a variance in these numbers?
supra
posted January 14, 2006 11:49 AM
What's your point? What if told you that the inlet valves flowed less than either one? Would you still care?
supra5677
posted January 14, 2006 11:55 AM
I thought I remembered that blais cycles said that the throttle bodies flowed more cfm's than the runners themselves.. I could be wrong.. Im talking about air flowing through throtttle bodies not the intake valves themselves..
Another question: Kawasaki quotes from the silver book that if they "didn't have noise restrictions they could probably bump it to 210hp".. what noise are they talking about intake noise or exhaust noise? Just a question..
Thanks,
supra
trenace
posted January 14, 2006 01:03 PM        Edited By: trenace on 14 Jan 2006 14:03
Of necessity, when the throttle bodies are connected to the runners and intake valves, the same amount of air flows through each.
The question is whether the restriction of the throttle bodies is significant relative to the restriction of the latter, and then if so, how significant.
I believe if you do a search on the Monster Snorkle, while won't find the exact good test that you propose, you will find sufficient reason to give it no credibility.
EDIT: Psycho already bumped it for you.
psycho1122
posted January 14, 2006 05:47 PM        Edited By: psycho1122 on 16 Jan 2006 06:54
The "Good" Information accumulates in the latter part of the Thread.......(Except Page 4, it gets "Out there")
The Numerical info at the begining holds true......
RAC4IT
Bergie
posted January 14, 2006 06:27 PM
If you provide the intake I will do it at the April meet.
posted January 14, 2006 06:36 PM
Of course Trenace, if they are all in the flow path. But, the maximum flow is determined by the most restrictive part of the path........
What do you think that would be?
D.
GUNNER
posted January 14, 2006 06:39 PM
V A L V E S I Z E
posted January 14, 2006 07:17 PM
GIve that man a titanium cigar!
GUNNER
posted January 14, 2006 08:01 PM
Oh Boy!!!! I won I won!!!!!!!!!!!!!!!!!
speedgene
posted January 14, 2006 10:42 PM
What is the fix for the leaky chambers? Do you seal it with marine grade (GOOP) glue, epoxy mix, gas weld, other? TY
E-tard
posted January 14, 2006 10:55 PM        Edited By: fish_antlers on 14 Jan 2006 23:13
similar to using dial-up over a VOIP connection, gene *wink*
speedgene
posted January 14, 2006 11:34 PM
Thanks fish, I have plenty tubes of 56k. I rather use a glob of V.92 though. It dries faster.
1122 says; "The "Good" Information accumulates in the latter part of the Thread......."
E-tard
posted January 15, 2006 05:57 AM        Edited By: entropy on 15 Jan 2006 17:47
Doug,
If you are implying bigger valves on the 12 give better performance, you are "flying in the face of conventional wisdom"(even on a built 12)
Most experts seem to say that the 12 (and the Busa) have perfectly sized stock valves for NA motors, even for my 1427 NA 15:1 motor.
I have NOT increased my valve size based on this expert/conventional wisom, but if you have thoughts in this direction, i'd sure like to hear 'em, yep.
On a related note, I went from stock 46mm to 48mm TB's and definitely got 3-4hp; did a sequence of dyno pulls over 2 weeks, same fuel, same motor, pretty close to same weather.
1. 46's, pulls,
2. put on 48's, pulls, gained 3-4 hp
3. went back to 46's, pulls, lost 3-4 hp
4. re-installed 48's, pulls, got back my 3-4hp
supra5677
posted January 15, 2006 07:57 AM
The intake valves on a zx12r are 33.4mm HUGE forget it
supra
psycho1122
posted January 16, 2006 06:28 AM
Gained 3-4 hp.
Is that "peak"? How did it affect power "under peak"??
TRNorBRN6001
posted January 16, 2006 08:07 AM        Edited By: TRNorBRN6001 on 17 Jan 2006 06:27
3-4 hp very nice, would be interesting to see that curve.
TFA 200MPH CLUB MEMBER!
posted January 16, 2006 11:57 PM        Edited By: entropy on 17 Jan 2006 10:51
Gained 3-4 hp.
I don't have the curves in front of me, but from my log:
9-Sep-05: dyno, Tejas dynojet 250: 213hp STD max w/48's , will try w/46mm TB's, 11 pulls
13-Sep-05: dyno, back to Tejas w/46mm's; lost 6hp peak wrt 48's (207 STD vs 213 STD), 8 pulls
30-Sep-05: dyno, SPAZ's mobil dynojet 250i @ Memphis Prostar; 48's back on, but was way rich, made 217 STD after a bit of tuning; est 20 pulls total
The question I always wonder about is just what is the difference at speed; 1/4 mi mph tells all, but various gremlins have prevented this test.
I am convinced there is benefit for my motor so i'm running the 48's (thx MM!), no more tests w/46's; i am not gonna screw with em no mo'.
I will however run a test of Hans vs OEM this spring (at the track)
psycho1122
posted January 17, 2006 06:31 AM
Still showing "Peak" #'s there entropy... and VERY nice BTW!
How about some #'s at 6,000 or so?
I agree, 1/4 mi tells all!
TRNorBRN6001
posted January 17, 2006 06:33 AM
The Texas Mile would be a good place to test the big snorkel also. Heard
a rumor Entropy might be attending in October. Bet if some one bought
Entropy the snorkel he would not mind testing it for us all.
posted January 17, 2006 07:38 PM
Entropy,
No, that wasn't my point at all. I've been pretty vocal about bigger valves being a waste of time. We're in total agreement on that. As for the bigger TB's, no problem there, either especially on a big 'un like yours. My comments were to point out the futility of this mod on a stock size engine with stock cams at stock available rpm.
D.
posted January 18, 2006 01:40 AM
Gary,
I have a Hans snorkle sitting on my shelf
posted January 18, 2006 01:41 AM
I'll see if i can find those curves, there around here somewhere.
posted January 18, 2006 01:44 AM
Entropy,
D.
Doug,
ahhhh, that's what i thought you'd said much earlier about valve size. I's hell being old and not remembering who said what
0.27787709236145 seconds processing time
