BIKELAND > FORUMS > ZX12R ZONE.com > Thread: tab under crank sprocket NEW TOPIC NEW POLL POST REPLY
aliveagain
posted December 26, 2005 08:08 PM
I removed the tab under the cam chain sprocket on the crank for ease of installation and disassembly.What was its original reason for being there?I didn't have any problems all last year,albeit a short one,just wondering if I made another screwup.
posted December 26, 2005 08:45 PM
?? what are you talking about...
Tab under cam chain sprocket?
osti33
posted December 26, 2005 08:51 PM
Are you talking about the tab that is cast into the lower case half??
aliveagain
posted December 26, 2005 09:01 PM
Yes,the tab cast from the case.
posted December 26, 2005 09:02 PM
if so that has to be cut or ground off....... that will not be a problem... and you dont have to split your cases to remove your cam chain....
aliveagain
posted December 26, 2005 10:00 PM
I popped it off with a large screwdriver and hammer.I was replacing my chain and no matter what I tried,I couldn't get the chain between the sprocket and the chain.It sure made the job easier but wasn't sure if it was for oiling or prevention of tooth skipping. thanx!
12r1
posted December 27, 2005 08:45 AM
As long as it turns out to be harmless, that's a super discovery ya made there. With all you guys are teaching me, I should dive into mine sometime.
jeff
12r1
posted December 27, 2005 08:53 AM
Sounds like the way I work on 'em, smack it off with a hammer ; )
jeff
0.24731397628784 seconds processing time
