BIKELAND > FORUMS > ZX12R ZONE.com > Thread: TPS signal? NEW TOPIC NEW POLL POST REPLY
yzfone
posted December 15, 2005 09:19 PM
TPS signal?
I need a TPS signal for a Wideband PC and for a Scnitz window switch with throttle position input. My question is will pulling two signals off of of the TPS effect the signal to the ECU and what is the best way to make the connection, they both have the wire taps the cut the insulation on the wire. tHIS IS ON A 2002 12
Thank you
MAXIMUS
posted December 16, 2005 05:54 PM
I believe that that tapping into that wire may cause a resistance change and can cause some problems, but the easiest way to tap into a wire in the tps is just to back probe it.
0.27973604202271 seconds processing time
