sailusvi
posted March 14, 2002 02:48 PM
Drag race'in help....
now I've ridden bikes hard all my life, 30 yrs worth. but I have never been down a drag strip, and really never raced anyone on the street.
I want to go to a little strip this weekend and try it out, its only a 1/8 mile track and will be up against cars more than likely. 5150 miles on my Y2K 12 with a muzzy pipe and timing advancer.
Any tips from my peers?
krexken
posted March 14, 2002 09:20 PM
Avoid the water box if possible. Street tires don't need a whole lot of burnout either. Release the clutch quickly til the bike moves smartly. Try to find the spot just shy of wheelieing right off the line. Don't ease off of the clutch, snap it out to the best spot to get you moving and then roll in the throttle and feed the gas. Hang on!
posted March 15, 2002 06:18 AM
Edited By: entropy on 15 Mar 2002 06:30
i can relate...
Sail,
I just started running my 12 last year so i can relate.
1. treat yr first few passes like you were beside a buddy at an isolated red light with no cops around. Just do what you normally do. Get the routine of cleaning the tire, staging, reacting to the light, etc. Don't try for 9's right off (it'll come).
2. when you are comfortable with the routine, then try:
- stage with rpm held between 4-5 grand.
- lean over the tank as much as possible.
- maybe stage with left foot on the peg, up to you.
- snap the clutch out, but hold onto it so you can pull it in if things start going airborne
- after the clutch is out, roll the throttle on as fast as you can, watch out for the top of 1st and second. If you aren't skootched down fully on the tank, it will surely wanna wheelie. Since you aren't lowered it may wanna come up no matter what.
- shift when the tach is "way up there", don't worry about exactly what rpm at first; it'll come
- don't bother preloading the shift lever and doing clutchless shifts at first; get comfortable with all the other stuff. You have plently to get used to without getting tricky at first.
3 post yr results here, we will enjoy hearing about it.
4. get a couple more Visa cards; you'll soon be needing them.
Good luck man, this is REALLY FUN!!!!
PS: where are you located???
kcadby
posted March 15, 2002 07:04 AM
Edited By: kcadby on 15 Mar 2002 07:05
ALL good advice!!!
I would do JUST AS Entropy and Ken said...go around the water...NO BURN OUT (first run or two)...pull up to the line and get used to staging..just "drive off like your TRYING to get a ticket from the COP sitting next to you" at a stop light ...
I WOULD "go around the water" then back the tire REAR ONLY into it just to get it wet so it's easier on the clutch to get it spinning though...stand up (get weight off of seat) just till it starts to spin...SHORT burn out on street tire will be fine (as already stated)...
I ALWAYS try to KEEP the front tire dry though...seen people lock the front brake after burnout and FALL...
Hurts the EGO...WAY more than the bike...usually...
If the traction SUCKS (don't know the track) let some air out of the rear tire...5Lbs at a time...down to about 20lb if nec...
Do NOT run back-to-back runs (wait at LEAST 15 min between runs) unless you ALREADY have that Master Card Entropy is talking about LOL!!! CLUTCH NO LIKE THAT!!!
MOST IMPORTANT (but NOT hard to do)...
HAVE FUN!!!
sailusvi
posted March 15, 2002 12:37 PM
Great advice, Thanks!
Hope the weather holds out for Sunday.
I'm about 1 hour NW of Austin. Going to "Temple Academy Dragstrip"....www.templeacademy.com.
any certain tire presure I should run? I'm 210 lbs.
posted March 15, 2002 01:36 PM
I'm about 210 (w/o leathers) myself, and ran 40psi with my 207. Once in a while i'd put the pressure down a bit, but us "substantial" folk don't seem to have as many traction problems as the anorexic guys.
sailusvi
posted March 16, 2002 03:59 PM
posted March 16, 2002 11:22 PM
Sail,
You ARE coming down to Houston for the Texas Shootout on 3/23 aren't you?
sailusvi
posted March 17, 2002 11:19 AM
light rain this morn'in......crap. maybe next time
Don't know if I can make it, self employment means it hard to plan ahead.....I will go if possible.
