osti33
posted November 16, 2005 02:54 PM
Anyone else remember piston buttons?
I was just sitting here thinking and piston buttons came to mind. They were nylon(I think) buttons used to hold the wrist pins in the pistons back in the day. You just put your wrist pin in you piston and rod then stick one button on each side of the wrist pin and you done. They were a lot easier to get in and out than the snap ring type of retainers they use today. I think so anyways.
I wonder why they changed to the snap ring type of clips they use now? Maybe someone with more knowledge than me knows.
Weight savings maybe...I wonder what the weight difference is? Hmmm.
Anyways, anybody else remember those things?
posted November 16, 2005 03:01 PM
The buttons would scrape the cylinder walls and wear out and then the wrist pin would start. Never could use them on 2 strokes either. Remember the spiral lock Weisco used? Only circle clips with tapered pins work well!
osti33
posted November 16, 2005 03:08 PM
quote: The buttons would scrape the cylinder walls and wear out and then the wrist pin would start. Never could use them on 2 strokes either. Remember the spiral lock Weisco used? Only circle clips with tapered pins work well!
Good info as usual Mr. Hill. I didn't know that about the cylinder walls. I knew you couldn't use them on 2 strokes. I do remember the spiral locks too. I just never knew why they went away from the buttons, but now I do.
Thanks for the info.
posted November 16, 2005 05:13 PM
ANd as you know, the Wrist Pin was not kind on the walls. The Buttons were fine for people that took the engines apart all of the time, but nowadays people want Longevity
posted November 16, 2005 10:13 PM
I know drag bike guys that use the buttons.....
I have thought about trying them but have never found any, but then again I did not look very much....
MM
johnnycheese
posted November 17, 2005 05:24 AM
Tony at MTC has them but you have to use a shorter pin
eastbaydave
posted November 17, 2005 06:30 AM
quote: Remember the spiral lock Weisco used? Only circle clips with tapered pins work well!
Yep. I built my GPz1170 w/Wiesco pistons & sprial locks. Was still running last I heard...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
harryzx-12
Tony lang sold mtc which I didn't know till I went to the prostar finals in gainesville. I went to the mtc boothe and asked where tony was and was informed that he had sold the company.
I remember the teflon buttons osti33! Never used them myself though.
posted November 17, 2005 07:21 AM
Pin buttons are still used regularly on engines that "come apart" often (mostly drag).
Properly fit they work fine and are a trouble free piece.
osti33
posted November 17, 2005 01:54 PM
Edited By: osti33 on 17 Nov 2005 13:54
quote: Pin buttons are still used regularly on engines that "come apart" often (mostly drag).
Good info Doug. I didn't know anyone still used them. I just remember they were a lot easier to get in and out than those snap ring style retainers they use now. I always seem to have to swear a couple times to get them in and out.
Anyone got any tips or tricks to get them in and out easier??
Ryan
posted November 17, 2005 02:12 PM
Yes, Make a tool! I took a small flat blade screwdriver (one that has a tip of no more than 1/8 to 3/16 inch wide) of good quality and round 1 side if the flat blade. then with a cut off wheel about 1/16 inch from the top on the other side make a small notch. the other tool is a hard steel Dental pick sharped edged.
I push in on the side of the circlip about 1/4 inch away from the end of the clip to raise it and take the dental pick to pull it over the screwdriver. and pish the screwdriver around the circle and usually in about 1/2 inch of movement they fly out.
SOme pistons have s small notch where about a 1/8 drill bit was used down to the groove which allows the dental pick easy access to the wire circlip. Putting them back in, I use a small set od Needle nose plyers with the ends no more than 1/8 to 3/16 inch wide with a curved and smoothed top and grab the clip in the middle and push down on the ends in the Groove while pushing inward on the clip. I usually get the clip right up to the edge of the piston and take a flat blunt punch and push it in place.
GUNNER
posted November 17, 2005 07:37 PM
I still have a couple of 1426 cylinders that are outfitted with buttons. Never have had the first problem with buttons.
238mph
posted November 18, 2005 09:34 AM
Same here, I've used buttons and never had any problems...
