BIKELAND > FORUMS > ZX12R ZONE.com > Thread: strocker crank longivity NEW TOPIC NEW POLL POST REPLY
jerry coomer
posted October 23, 2005 05:16 PM
will a welded up stroker last in a zx 12? and is it even worth messing with?
kawachan
posted October 23, 2005 05:34 PM
If heat-treated right, yes they will.
Krexken had one that I personally saw go 159ish on motor. He rode it everywhere and raced/rode it all the time. Still running as far as I know.
MadMike had lots of passes on his too.....
RED NINJAS RULE!!
trenace
posted October 25, 2005 04:30 PM
There have also been very many short-lasting results.
If anything it seems to me that the number of guys reporting a long lasting result (by street standards of mileage, as opposed to "I got a full season out of it") is considerably less than the number that have had failures at rather low mileage.
krexken
posted October 25, 2005 04:38 PM
I have yet to hear of a stroker with a crank failure in a 12. Maybe bearing failure but I believe that's totally unrelated. Yeah, my old bike still runnin. Almost 5 years later. No rebuilds. Just a little nitrous every now and then. LOL
What's up Chan Chan? My old track is closed. WAHHHHHHH!
trenace
posted October 25, 2005 05:06 PM        Edited By: trenace on 25 Oct 2005 18:35
Well, if totally unrelated then it's quite a coincidence how high the failure rate has been. There's also a direct possible causal relationship, namely that when one increases stroke, piston accelerations increase, which increases bearing load. There is also an increase in peak piston acceleration -- kind of a whiplash effect -- associated with reducing the rod/stroke ratio, which with the stroker goes to a regime generally not considered so suitable for a performance engine and certainly not preferable, namely down to the mid 1.4's range.
Imagine a 350 Chevy with 5.06" rods, and that's the kind of severe short rod situation we're talking about with force-fitting a 60mm stroke into a ZX-12R engine, if that helps picture it. It is not within any engineering standards for a production motor at that point, or certainly not a high-performance motor anyway.
However, I can't disprove that it might not be pure coincidence that the failure rate within fairly modest miles (by most street standards) is so high. Quite a coincidence though if so. Certainly stock motors aren't suffering bearing failures at remotely that rate. If they were we'd have 1000 reports of it or more, given the number of members on this board.
rac4it
Bergie
posted October 25, 2005 05:49 PM
99% builder, 1% parts.
NOX
PMRA / TMRC Super Street 4022
posted October 25, 2005 09:51 PM
It is true that short stroke, big bore is better, but at some point you run out of bore. I would think a beefier low end, stock stroke, cams, and a 1317 would be a great package, and could be turned at a higher rpm for more power. At least that is what I am wanting to do right now.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted October 28, 2005 06:20 PM
Amazing insight, Bergie.
D.
johns
posted October 30, 2005 05:47 PM        Edited By: johns on 30 Oct 2005 17:49
Jerry, where are you from, you have to be the Jerry Coomer I know from Louisville?
2006 ZX-14 (sold)
2012 ZX-14R (Brock's Perf. project bike Louisville Slugger)
2013 Honda VFR1200F
2003 124 C.I. H.D. Super glide
Hells Dark Lord
living life, and loving it.
posted November 01, 2005 06:46 AM
dam lots of Louisville guys on here...bhut I never see those Zx12's out whats up with that?
bossman12r
posted November 01, 2005 01:14 PM
The only thing I lost in louisville, Ky was my ex wife.
gen 4 zx10 is fast
johns
posted November 02, 2005 01:47 PM
Jerry Coomer
If this is the Jerry Coomer I know from Louisville he owned a couple of very fast Hayabusas and some very fast Chevrolets. Last I heard he got out of dragracing bikes.
2006 ZX-14 (sold)
2013 Honda VFR1200F
0.33950304985046 seconds processing time
