BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Ok here's what I need to know... NEW TOPIC NEW POLL POST REPLY
billbisby
posted September 03, 2005 09:58 PM        Edited By: billbisby on 3 Sep 2005 22:59
Made a u turn in front of my house day before yesterday to check my mail.. couldn't make the cut and bike went down.. it was only down a short while until my son and his friend helped me pick it up and put it in the garage.. It's an 03 will about 5K miles.. I started it up today and motor sounded a little funny so i shut it off and let it set for a minute or so and started it back up.. Oil light won't go off... I didn't want to run it like that so I killed it and restarted it two or three times for about 15 seconds or so and oil light won't go off.. What's up? Where is the sending unit? And, if that's not what is wrong then what do I look for? Thanks in advance for any guidance or help.. Mr Bill
scooter trash
posted September 03, 2005 10:03 PM
Simple question:
How long did it run on its side?
> 30 seconds is a problem, > 60 seconds is definitely a problem.
frEEk
posted September 04, 2005 12:27 AM
shouldnt run on its side at all. has a tipover switch that shuts it off (as i understand it, and my experience confirms).
i'm thinking, try starting it while someone holds it upright, then see if the oil dissapears from teh sight glass as the pump moves it from the pan to the rest of the engine. if it doesnt move, then u know the pump (or something) is buggered.
posted September 04, 2005 05:26 AM
You may have an airlock in they system. Get the bike up on stands, change the filter and oil. When you change the filter, fill it with oil. Don't just pour oil in and call it good. Pour oil it, roll the filter between your hands and work it into the filter elements. Keep doing this till oil starts weeping out of the little holes in the top. Top the filter off, then put it on the bike. There's a couple ways to roll the motor over without starting it. Easiest is pulling the fuse for the fuel pump relay. Roll the motor over, and you should see the oil pressure light go out after a few seconds.
OutsiderZX12R
Street Racer
posted September 04, 2005 06:09 AM
It does have a tip-over switch, but there has been times that the switch has been known to not work.
OutsiderZX12R
2000 ZX12R-A1
  Ignore this member    Click here to visit OutsiderZX12R's homepage.
NinjaNick
'08 ZX14 (Blue)
posted September 04, 2005 06:56 AM        Edited By: NinjaNick on 4 Sep 2005 07:57
Not being smart or anything, but just wanted to state some carelessness...
If you couldn't make the U-turn appropriately, you know you can stop the bike, put feet down, back it up a little bit and then finish the turn. haha, but seriously though, sorry about your mishap.
billbisby
posted September 04, 2005 07:08 AM
Thanks for tips my friends.. I'm upset that a fall over could potentially do major damage.
zx12adam
Member
posted September 04, 2005 02:22 PM
That's motorcycles for ya, but what would you expect when a 550lbs object hits the ground?
238mph
posted September 04, 2005 06:09 PM
Good thing Adam Ant wasn't under it... dood!!!! You should have never told me you
weigh 150lbs!!!! hahahahahaha
  Ignore this member    Click here to visit 238mph's homepage.
tuusinii
posted September 04, 2005 10:42 PM
No need to change the oil filter. Just open it a littel (watch out there is oil) then start the engine with the oilfilter little loose. After couple on seconds oil starts to come out of the filter. Then shut the engine up and close the filter as fast as You can. And You're good to go. Check the oil level though because some of the oil has come away.
The filter don't have to be open very much - just so much the there is air passage. I do this after every oil change.
tuusinii
posted September 04, 2005 10:45 PM
And it is weird that accoding the service manual US and Euro spec ZX12 have different angle on the tip-over swicth. The US-model dosen't shut the engine untill much later than Euro spec. Maybe it is You law system and Kawi don't want no possibility of engine shutting when not needed. But the same time it may not work the way it should.
yzfone
posted September 05, 2005 06:59 AM
When mine got knocked over i had to prime the pump.
billbisby
posted September 05, 2005 07:40 AM
Once again thanks for suggestions and help on this manner.. I'm waiting for my son to help me put it on stands in a day or so.. Will post back.. Mr Bill
osti33
posted September 05, 2005 09:05 AM
Yep. Just crack the filter a little and start it up. When the oil starts to pump out screw the filter on the rest of the way. The pump is now primed...
Check your oil level after you do this.
billbisby
posted September 05, 2005 10:20 AM
I love you guys.. in a manly way of course!!!!! Smile
billbisby
posted September 10, 2005 07:10 PM
Ok here's the skinny.. Did the loosen the filter thing and wa la oil light goes off...........
Hurrah thank you for tips.. I'm back in action on my slower green 12R.... Later
BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Ok here\'s what I need to know... NEW TOPIC NEW POLL POST REPLY
0.3260281085968 seconds processing time
