BIKELAND > FORUMS > ZX12R ZONE.com > Thread: assembly lube: who uses it??? NEW TOPIC NEW POLL POST REPLY
posted August 04, 2005 09:00 AM
i came by a tub of Red Line Assembly lube and wonder about using it. The manual doesn't seem to mention it...???
Q: any of you folks "out there" use it? If so, what parts do you put it on, and do you apply it sparingly?? Liberally??? cam lobes?? valve stems??? gears?? cam chain?? Dare I ask; crank journals?? The ole lady???
Any observations, tips, hints, best practices, etc would be much appreciated.
posted August 04, 2005 09:39 AM
LOL.. for sure the old lady!!
I use it on everthing except the rings/pistons....
and I use lots of it...
slug
Out in search of my mind...
posted August 04, 2005 09:45 AM
+1 on madmike's comments
liberally apply it, bearings gears, anything that normally requires an oil film to prevent metallic contact
this allows engine time to get oil pressure up the first start.
i use the black moly engine assembly lube. works great lasts long time.
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
posted August 04, 2005 10:10 AM
When I install new Pistons and / or Rings, I use "ND-30" SA rated Oil on the Pistons and Rings so that they will at least have a Chance in Hell0 of breaking in. Then I use the cheapest Honda 10 w 40 I can find "IF" I replaced the Bearings like you are. If no new Bearings, then I use ND-30 for about 50 miles and never go over 4K Rpm (I figure that the Old cars back in the 30's and 40's and even early 50 could handle 4,000 rpms)
kzz1
"Show me whatcha workin with"
posted August 04, 2005 10:27 AM
yep.. use the stuff from ARP. use it on the bearings, cam lobes and oil pump gears.
osti33
posted August 04, 2005 12:24 PM
Yep, I use it on everything.
Marcos Peguero
posted August 04, 2005 01:07 PM
+1 here
  Ignore this member    Click here to visit Marcos Peguero's homepage.
scooter trash
posted August 04, 2005 03:34 PM
Definitely. I even use it on the cam lobes after something as routine as doing the shims.
posted August 06, 2005 01:49 PM
Is the starter of this thread Carl?
posted August 06, 2005 03:39 PM
nope; is was Karl...
posted August 06, 2005 06:45 PM
Karl, This is Bert.
When you met me at HRP I was on a green ZRX and then made the switch to
a ZX.
What I want to know is what has happened to our friend Zack (EZ)
I can't get him to answer the phone and we are tight.
Any word???
I'm sure he's ok.
Prolly in ole Miss.
Just curious.
slug
posted August 06, 2005 07:34 PM
oooh someone else that spells it correctly
posted August 06, 2005 09:30 PM
Bert,
I haven't talked with Zack in a while, but I see him posting on Labusas now & then. I assume he is moved completely to Miss.
Slug,
there is only one manley way to spell it!
OutsiderZX12R
Street Racer
posted August 06, 2005 09:53 PM
I agree!!
OutsiderZX12R
2000 ZX12R-A1
  Ignore this member    Click here to visit OutsiderZX12R's homepage.
eastbaydave
posted August 07, 2005 07:27 AM
yep, liberally w/Red-Line assy. lube. I drench the insides w/it...
first start up, pull plugs & run starter for awhile AFTER the pressure light goes out.
install plugs, start...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
posted August 07, 2005 09:17 AM
...run starter for awhile AFTER the pressure light goes out...
damn, that seems so obvious (AFTER you said it)
thanks
slug
posted August 07, 2005 05:48 PM
what's the difference between running the engine 100 revolutions on starter or 100 revolutions under fire? once the pressure is up it's up, and with proper application of the asembly lube there won't be ANY lack of lubrication even BEFORE the oil pressure builds up (assuming you are using the high-pressure moly engine assembly lube)
posted August 07, 2005 09:50 PM
100 revs on starter without plugs would seem to have much less pressure on moving parts, than 100 revs w the engine running. Just to check everything is fine, get oil everywhere it should be.
slug
posted August 08, 2005 04:02 AM
that's what the asembly lube is for....
posted August 08, 2005 04:25 AM
i do understand that, but i'm looking to eliminate every possible culprit which might be limiting my motor life.
0.26528477668762 seconds processing time
