Wildman
I only look confused
posted June 25, 2005 11:40 PM
Oil Light?
Hey, Long time no see...
I'm still around a little.
Anyhow, my bike (2000 ZX12, green) has started occasionally flashing the oil light a little bit. It is not low on oil, and never has been. The oil has never been allowed to get dirty, running full synthetic.
Is there an issue with the sending unit or the wiring? Or should I be looking for an actual oil pressure problem?
I'm on vacation this week and wanna get this fixed pronto so that I can get some riding in, so any help is greatly appreciated.
Thanks,
Owen
If you build something Idiot Proof, The world will build a better Idiot.
zxlnt
posted June 26, 2005 04:06 AM
I would start with the wiring and sensor first, then look for an oil pressure problem...
Start with the simple things and work from there.
ninja12
posted June 26, 2005 06:00 AM
check sensor if the wire is on and tight.
Main bearing are gone.
Pull your oil pan to check it.
psycho1122
posted June 26, 2005 08:07 AM
I would rule out the sender with a gauge. Use -4 line (same inside dia. as sender).
I then would pull the pan and inspect and clean the screen.
If you main bearings were "Gone" you would have some noise and excessive heat. Do you? OR, does this just happen at idle. If so, warm or cold?
Next, I would order and replace the oil pump rotor. These are CHEAP and easy to replace. They are right behind the water pump and run off the same shaft.
You will be suprised how much the rotor is "Nicked up". Over time this will affect how efficient the pump is.
When installing Rotor assembly, Put some Lithium Grease on the lobes. This will pre-lube and give good suction at start up.
I would also UNPLUG the Injectors before initial start up. This will allow you to "Prime" the system. When you see pressure on the gauge, plug in the injectors and then fire. Plug is located on the TPS side of the rail and right under the first two throttle bodies.
Hope this helps!
Wildman
posted June 30, 2005 12:22 PM
Update;
I replaced the oil and filter. I had been using a Fram oil filter, but I went back to a Kawasaki filter. The oil was not low, nor was it dirty. I probably only had 1000 miles on that oil change.
So, now the bike seems to be completely cured.
Your mileage may vary, but I'll never use another Fram filter on my bike.
posted July 01, 2005 09:04 AM
you might want to drop the pan, just do to the age of the bike your pickup screen might be clogged a little. if the light comes on again I would suggest that.
MM
posted July 02, 2005 07:38 AM
stock filter is always cheap insurance.
Wildman
posted July 02, 2005 09:27 AM
quote: you might want to drop the pan, just do to the age of the bike your pickup screen might be clogged a little. if the light comes on again I would suggest that.
MM
Hey Mike, how's it going?
Was going through pictures the other day and found a couple of you and your GF (wife now?) at the track...
Anyhow, If I get any more oil light flashes I will get in there and pull the pan. Probably rip into the oil pump too just to be sure. I looked at the wiring and it all looks good, I pulled and wiggled wires all over the bike trying to replicate the thing and couldn't.
I'm hoping the inside of the engine is pretty clean, I've always been good about oil changes, always used good oil, and I'm not as hard on the bike as a lot of the guys around here. (Still on the stock clutch, no dragstrips)
Hopefully, the issue is cured. Frankly, I'd rather ride it than work on it.
Thaks for the tips,
Owen
MAXIMUS
posted July 17, 2005 05:03 PM
Alot of the times there is a problem with the switch and the connector, thats where i would start. Thats the easiest place to start.
Ra12r
posted July 18, 2005 06:18 PM
I had your problem, mine was worn MAIN BEARINGS. The bike did NOT get hot as the bearing were not seizing up. ( It would if it was seizing the crank though). I would pull the oil pan and check for shavings. By the design of the plug, shaving do NOT easily come out on changing the oil to see them.
What is your idle speed, maybe the bike is idleling too low!?
