BIKELAND > FORUMS > ZX12R ZONE.com > Thread: installing cylinder NEW TOPIC NEW POLL POST REPLY
aliveagain
posted May 16, 2005 06:18 PM
installing cylinder
I'm having a problem keeping the pistons straight when trying to get them in the cylinder.Every time they'll go in crooked causing the rings to pop out of the ring compressors.Any tips and advice would be much appreciated on how you install the cylinders.thanx
posted May 16, 2005 06:38 PM
you can place 2 small bars (smooth)under the pistons to help keep them straight. or email me your address and I can send you the kawasaki tool, to borrow, and just return it to me when your done with it.
Mad Mike
osti33
posted May 16, 2005 08:03 PM
I did it like mike. I used some small stainless tube under the pistons to keep them straight. With those and a couple of ring compressors you should be fine.
aliveagain
posted May 17, 2005 02:32 AM
Just out of curiosity,which side do you put the sealant? The underside of the cylinder or on top of the casing? Seems like the underside because otherwise I run the risk of scratching it off with the pistons.
aliveagain
posted May 17, 2005 02:46 PM
Well I'm happy to report ,the pistons went right in once I gave them a little support.It was crucial that the ring gaps were at 6 and 12 oclock and then they went right in in about 30 mins.Next step is to clean the insides of the bored out head gasket.
osti33
posted May 17, 2005 05:08 PM
Glad to hear it went well...
posted May 17, 2005 08:56 PM
Place the gasket with the raised bead "up". If using a stock gasket, never add any type of sealant. Same goes for head gskts. TH ehead gasket is a bitch to get "clean" if itt hasn't been machined in aproper fixture. The grade/type of stainless used tend to produce slivers and shards the more you work to clean the edge. Very much a PITA.
eastbaydave
posted May 19, 2005 06:00 AM
Mad Mike
YOU FUCKIN'-A ROCK DUDE....
three cheers for Mad Mike.....hip hip hooray! hip hip horray! hip hip horray!
the world needs more kind-hearted peeps like you...
ebd
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
rac4it
Bergie
posted May 19, 2005 06:07 AM
that almost sounds like ebd is gay for mm ;-)
posted May 19, 2005 12:30 PM
your just being nice cause my airshifter is gonna kick your ass...
rac4it
Bergie
posted May 19, 2005 03:55 PM
you better get some more seat time; me being off a bike for almost two years isn't going to help you much! :-) practice up before I make you my bitch
12r1
posted May 19, 2005 08:08 PM
I'd love to meet you guys sometime, LOL.
And make you both my bitches,he he he.
jeff
0.25869202613831 seconds processing time
