BIKELAND > FORUMS > ZX12R ZONE.com > Thread: FI Light NEW TOPIC NEW POLL POST REPLY
ddpete3
posted February 17, 2002 10:49 AM
FI Light
Goin down the mountain...2nd gear, just using the rpms to slow the bike down, not really hitting the gas...FI light comes on...but only in second...goes off when I shift....any ideas?
  Ignore this member    Click here to visit ddpete3's homepage.
eric00zx12r
posted February 17, 2002 12:12 PM
I had a simular problem. If I was getting on the bike in first, second, and third, then eased up and shifted up to sixth, the FI light would come on every time. If I took it easy, the light woulen't come one.
I finally got my dealer to get me a new gear position sensor under warranty and haven't had a problem since.
I was a wierd deal. I coulnd't figure out why getting on it would make a difference but something was being effected by it.
Since replacing the sensor, I've had zero problems. Something you might want to look into.
Eric
00ZX-12R
Candy Persimmon Red
ridgeracer
posted February 17, 2002 04:50 PM
I designed my own gear position indicator using the stock gear position sensor. I have noticed that it will some times mess up in the upshift from 1st to 2nd and also in neutral at idle. When it does if I just tap the gearshift it will correct itself. I would be willing to bet if you pulled the ECU codes after it happens you will find the bad gear position sensor code.
BlackMandingoWarrior
posted February 17, 2002 05:34 PM
RidgeRacer...
How do you pull the ECU codes?? Is it done through the pc3s and is there a list os the codes and what they mean???
BMW
The QuickSilver Ridin MoFo
Phil
posted February 17, 2002 07:07 PM
BMW, all the codes and how to find them are all detailed in the shop manual.
"Look at Dad, trying to look young again."
0.22729301452637 seconds processing time
