BIKELAND > FORUMS > ZX12R ZONE.com > Thread: ZX12 WITH NITROUS SYSTEM NEW TOPIC NEW POLL POST REPLY
litozx12
posted April 22, 2005 02:51 AM
Desde que monte el sistema de nitro el power commander hubo que ajustarlo para que trabaje en alta pero y cuando no este usando el sistema?
Beware busas of zx12
ricksgsxr
posted April 22, 2005 05:17 AM
Me no savy. Bike should be mucho rapido with nos!
posted April 22, 2005 08:09 AM
VOZ! Can you translate?
ricksgsxr
posted April 22, 2005 09:01 AM
Babelfish says
Ever since it mounts the system of nitro power to commander was necessary to fit it so that it works in discharge but and when the this not using system
To respond in spanish:
http://babelfish.altavista.com/tr
ricksgsxr
posted April 22, 2005 09:03 AM
How Could i have forgotten too add? .. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
BA
posted April 22, 2005 02:33 PM
I'd check the reverse rev-limiter, it may be bad.....
litozx12
posted April 22, 2005 08:20 PM
My power commander is setting only for nitrous but when im not using nitrous what? in gasoline my power does not work, i need a device with 2 memories to storage the maps with nos or with gasoline.
ZXLNT
posted April 22, 2005 11:05 PM
I understand you have it mapped for nitrous so it doesn't run well when not spraying nitrous. U need a device to hold multiple maps. The Yoshimura EMS does what you want to do....
0.25812602043152 seconds processing time
