BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 2004 Rear Shock assembly NEW TOPIC NEW POLL POST REPLY
zx23rr
Mahogany Bomber Pilot
posted February 15, 2005 05:31 PM
Okay - who knows what the differents is between a 2000 Zx-12r rear shock and a 2004 Shock? Would it be a good upgrade? Is it a direct bolt-in. I would assume the spring is different for starters!!!
posted February 16, 2005 04:27 AM
Not worth much trouble to change. At the very least a Penske swap would be worth the trouble.
beansbaxter
posted February 16, 2005 06:23 AM
penske or ohlins?
EastBayDave
posted February 16, 2005 08:14 AM
either/or....about the same. Top end Penske is much more expensive than the Ohlins, but it has both high & low speed compression/rebound dampening adjustments. It also has a lightweight Ti spring...= $1200.
They also will set it up for you prior to purchase which your average Ohlins dealer will not; you can also send it back free for adjustments if you get the lower end unit without external adjustments.
http://www.le-suspension.com/
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
posted February 16, 2005 02:21 PM
I have the Ohlins and wouldnt trade if for the Penske.
Either one is nice. As far as "setup"... my ohlins worked fine outta the box and cost about $200 to have resprung/valved 2yrs later.
Marcos Peguero
posted February 16, 2005 08:06 PM
Hyperpro is a good option.
  Ignore this member    Click here to visit Marcos Peguero's homepage.
0.2774441242218 seconds processing time
