BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Clutch isues NEW TOPIC NEW POLL POST REPLY
Marcos Peguero
posted September 28, 2004 04:52 PM
Clutch isues
I was at the drag strip for the first time. It was a drag strip in the street that some company makes to sell rum here in DR.
1- I was very fast the first couple of times
Then I draged the clutch a lot and at the end of the strip the clutch felt like It was gone then I let the bike cool down and It was fine.
Did I burn the clutch???
My clutch is a model A stock with dilled holes in the stock hub.
Recomendations????
  Ignore this member    Click here to visit Marcos Peguero's homepage.
motorcycleboy
posted September 28, 2004 05:28 PM
Call Muzzy. ;-)
New clutch time for you M.
deathpulse
posted September 28, 2004 07:39 PM
Get the Muzzy Basket AND clutch - its time!
posted September 28, 2004 08:13 PM
Flat spot the puller shaft and use good oil!
posted September 29, 2004 01:43 AM
marcos,
yank yr clutch plates and see if you have any black steels. Sometimes they get so hot they warp and will "hang up" causing the clutch to slip or creep or both. Then its time to call Ron Ayers.
oof440
posted September 29, 2004 04:16 AM
i'm sorry, this may seem like a silly question but what does flat spot the puller shaft mean?
posted September 29, 2004 04:35 AM
ZX12, Clutch, Issues.. LOL.. Dude you have got to be fucking kidding... LMAO....
and oof.... what they do is take a grinder and grind a side of the puller shaft that goes into the Hub. it alllows a little more oil into the clutch.
psycho1122
posted September 29, 2004 08:16 AM
What is with this "Flat Spot" buisiness??!!??
Even Big K finally did the proper mod to the clutch to get oil "INSIDE" the hub on the 05.
The "Puller Shaft" on the clutch pressure plate is HOLLOW. It slides inside the Input Shaft of trans. Input Shaft has metered oil supplied to it.
All you have to do to get a good supply of oil inside your drilled hub is to have the Pusher Shaft cross drilled .040 just behind the landing for the needle bearing. DICK SIMPLE Gentlemen!
Canadamaxxer
posted September 29, 2004 08:47 AM
psycho,
Will the 05 puller shaft work in older models?
psycho1122
posted September 29, 2004 08:53 AM
That is a Good Question....
I have concidered ordering one to have a spare and save me from paying to have one EDM drilled. PLUS it would be nice to see if the Part # is a cross reference AND to see exactly how Big K drilled the Pusher!
your car is slow
Fuck Nitrous...Got Boost?
posted September 29, 2004 09:08 AM
flat spot = grinding a mm or so off the shaft along its length to create a flat spot in order to allow for oil flow.
Do not taunt happy fun ball!
posted September 29, 2004 10:25 AM
psycho.... not everyone has access to EDM...
NINJA12
posted September 29, 2004 11:18 AM
I recommend that you pull the clutch apart and replace the
steels and fibers that are damaged. If you catch it early
you can save the rest of the clutch pack, If not you will burn everything.
Recomendations????
Marcos Peguero
posted September 29, 2004 04:28 PM
I will pull he clutch apart and see if there is any damage in the clutch and replace the steel an fibers damaged and grind a mm along the side of the
?ROD,CLUTCH RELEASE part 46102?
Im using motorex 10w 60 oil in the bike.
What makes me wonder is that th clutch whent fine all the way home 175Km of hard riding.
What else do I need to do?
Thanks guys for the input.
Marcos Peguero
posted September 29, 2004 04:29 PM
PS I will put in the bike the zx6 2000 clutch springs at the same time.
psycho1122
posted September 29, 2004 08:05 PM
There is the right way to do things and then there's the shade tree way.
Why did Big K mod the pusher the way they did?
EastBayDave
posted September 30, 2004 04:35 AM
my clutch is dry as a bone....only a lil' dampness on a few plates...
I wanna know if the 05' pusher will work in the older bikes...someone go out & be the guinea-pig tester...
Anyone got pics of the "flat" machined on their pusher shaft?
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
your car is slow
posted September 30, 2004 07:20 AM
it looks the same as if you imagined it in your head. I just put mine on a bench grinder.
psycho1122
posted September 30, 2004 07:58 AM
Not much oil will enter the hub with the Pusher "Flat Spoted" when the clutch is engaged. The pusher has a small diameter landing that butts up against the input shaft.
The method I developed over 4 years ago and now Big K uses allows a constant spray of oil during engine operation.
I will be checking into the 05 pusher.
your car is slow
posted September 30, 2004 08:43 AM        Edited By: your car is slow on 30 Sep 2004 09:50
yea...it wasnt a complete solution..but every little bit helps.
Hell yea ill buy an 05 puller if itll fit...honestly dont see why not.
I have to place an order to ronayers anyway
aight..so it seems neither the Kaw website..nor ron ayers has an updated parts catalog for the 05 line.
WHo can get me the part # for the 05 puller shaft?
Ill order one today.
posted September 30, 2004 09:59 AM
Grind the shaft so that the Flat side is about 1/4 to 5/16" wide. That will add more Oil!
NINJA12
posted September 30, 2004 10:32 AM
The oil only comes out when the cluth is pulled, unless you also
grind into the bearing seat.
psycho1122
posted September 30, 2004 11:50 AM
Grinding the shaft is a stone age approach.
0.29606819152832 seconds processing time
