BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 1290 problem NEW TOPIC NEW POLL POST REPLY
riceracer12r
posted September 25, 2004 11:28 AM
1290 problem
just got my bike back... got the 1290 kit mapped and stuff made 190 hp runs strong but, when i hit the throttle and let off of it, it cuts off. this really sucks when riding. Is this a mapping problem or is this something that is a result of a line not being properly hooked up on the throttle bodies? Please help
1290 akrapovic k&n muzzy shifter 10inch arm
hoping for some 5.70's
is this possible with mid to low 1.40 sixty foots?
ZX1290Rider
posted September 25, 2004 08:24 PM
My 1290 does the same thing.
ZX12Rider in the Dirty Mo
Canadamaxxer
posted September 25, 2004 08:46 PM
Both of my 1270's will do this every once in a while...I have had it happen to me while decelerating at a stop light..that type of thing. I would assume that it's mapping...but I have no idea how to fix it. I think the first step would be to identify if the rpm at which the problem first occurs is consitant. If it is consistant I would try to add fuel to the 0 and 2% columns at that rpm and also 500 rpm's above and below and see if that makes it better or worse.
lonniemac
posted September 26, 2004 05:37 AM
i had that problem i advanced the timming at o and 2% throtle to 2 -3 degrees. and also added fuel at arround 6 % in the 500 to 3000 col.
riceracer12r
posted September 26, 2004 06:26 AM
Thanks ill try that and get back
posted September 27, 2004 07:05 AM
Add some fuel to the "0" Throttle position (5 to 10% above and below the problem and 15 to 20% at the exact RPM where the problem is) this is like an accelerator pump to give you a little fuel when the throttle is closed
zx12r4play
Dirty South
posted October 28, 2004 06:39 AM
posted September 25, 2004 12:28 PM
1290 problem
ZX1290Rider
posted September 25, 2004 09:24 PM
Have you guys found out what the problem was, and how did you fix it.
posted October 28, 2004 07:39 AM
It's all in the mapping.
posted October 28, 2004 11:49 AM
What Doug said and the Mapping problem is usually in the area where I mentioned. When you close the throttle, you are getting little or no fuel. When you get back on it, the "Extra" fuel you need is missing and the Bike stumbles!
0.22112798690796 seconds processing time
