BIKELAND > FORUMS > ZX12R ZONE.com > Thread: starter help NEW TOPIC NEW POLL POST REPLY
bossman12r
posted August 29, 2004 12:30 PM
starter help
Ok, the bike has power and I have power at the cable on top of the starter but the starter does not turn. Is the starter bad, I just starter it last night.
gen 4 zx10 is fast
your car is slow
Fuck Nitrous...Got Boost?
posted August 29, 2004 12:34 PM
everything function normally when you turn the key?
Gauges sweep? lights work?
Kill switch isnt in the "off" position is it? (to quote a phrase..."Ask me how I know")
Do not taunt happy fun ball!
bossman12r
posted August 29, 2004 02:26 PM
Yes, I can hear the relay clicking but the starter in not turning. I tried the clutch pulled in the kick stand up and down, put in gear out of gear. I put it in gear put a socket on the front gear and turned the motor a little nothing.
gen 4 zx10 is fast
ZXLNT
posted August 29, 2004 06:48 PM
Get a voltmeter and measure the battery voltage and then measure it when you try to start the bike.. Then let us know what it says.
diablodcielo
posted August 29, 2004 07:21 PM
I had to replace the starter relay switch on mine, was giving me all kinds of trouble, how about the tip over switch?? I dont remember where its at, but that's other thing u can look at. Bypass the starter relay and send power straight to the starter (thats how I found out it was my relay)
diablodcielo
posted August 29, 2004 07:22 PM
ooops u did that all ready lol
bossman12r
posted August 30, 2004 03:53 AM
It measured 12.19 with the starter button pushed. I measured the starter cable to see if it the starter was grounded but it read open. I was messing with the NOS and grounded a power wire. It burned up the wire going to the WOT so I fixed that. The when I tried to start the bike nothing. So I check all the fuses under the tank cover. The NOS has the relay insatlled which has to power wires going to the battery positive side.
gen 4 zx10 is fast
Ra12r
posted August 30, 2004 04:58 AM
Did you straight jump your starter?
Is your battery charged enough?
Is all wires connected?
bossman12r
posted August 30, 2004 06:35 AM
Yes all the iwres are connected. I put the bike in gear and took a breaker bar to spin the motor and the starter spun too. So it is engauged when it is not supost to be. Does it have a bendex like a car that pushes the starter gear into place?
gen 4 zx10 is fast
Five 0
posted August 30, 2004 06:36 AM
starter
Put the bike in gear and rock it forward. We burn the starters up from time to time when spinning the cars backwards. Once I rolled the car out of the trailer and my hand slipped off of the clutch. I heard the starter make a weird noise then it would not start. I rocked it forward and it started working again.
5-0
johnnycheese
posted August 30, 2004 07:50 AM
Boss man hook a battery directly to the starter motor if it turns you have a wiring problem if it doesn't you need a new starter. it is that easy
posted August 30, 2004 07:52 AM
If everything points to juice getting to the starter but not starter rotation(all you can hear is the relay click)-
The starter gear is always engaged. It's has a roller/ramp clutch in the gear assy. that will lock up when turned backwards. The starters have a habit of having the brushes come adrift when they get worn short. Take the starter apart and you'll probably find one of the brushes out of the holder. Just put it back in and re-assemble. You can purchase a new brush assy. found on the fische if you need to.
Doug
bossman12r
posted August 30, 2004 05:18 PM
Thansk for all the help. The spring that pushes the brushes some how jumped off. I guess the gremlin got mad after I shocked him when I was working on the NOS system. So he got me back by kicking the spring off the starter.
gen 4 zx10 is fast
slug
Out in search of my mind...
posted August 30, 2004 06:11 PM
good deal. and more knowledge gained.
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
DoTsTeR
posted August 30, 2004 06:23 PM        Edited By: DoTsTeR on 30 Aug 2004 19:26
Not that it matters now as it pertains to this solved thread but...
I see in the service manual they talk about the built in diagnostics mode and what all the error codes mean. It tells you if any sensors/whatever are failing.. etc etc Looks pretty in dept and no special stuff needed.. ya just short some wires to get it into one of two diagnostic modes...
Yet, I have never heard anyone on the forums mention using that..
Has anyone ??
I almost did when my used engine wouldnt start but I figured out the issue before I got to that point.
  Ignore this member    Click here to visit DoTsTeR's homepage.
ZXLNT
posted August 30, 2004 11:12 PM
Yeah I have played with it a little bit just to see if any error codes in there. But I didnt' get anything. Would be nice if it had an OBDII set up like the Triumphs do..
posted August 31, 2004 02:49 PM
Since I worked on one of these last weekend, I had an idea. Maybe before you put the spring back on, put a little dot of TIG weld on the top of the stud, giving it some resistance to coming off. Sonmething to "snap over". We'll have a look at it on the race bike.
Doug
bossman12r
posted August 31, 2004 07:18 PM
That is a great ideal Doug, if it happens again I will be sure to do that. But unfortunately I have it all back together now!
gen 4 zx10 is fast
0.27358293533325 seconds processing time
