BIKELAND > FORUMS > ZX12R ZONE.com > Thread: y2kzx12 NEW TOPIC NEW POLL POST REPLY
justoyz2
Justoyz Racing
posted January 25, 2002 02:30 PM
y2kzx12
Are there any gain by installing a set of cam(larger) in a 12 motor(stock) If so, how much of a gain should be expected. At the present moment, I am looking at a set of web. Is the gain worth the price.
Y2KZX12R
CompetitionCNC.com
posted January 25, 2002 04:01 PM        Edited By: Y2KZX12R on 26 Jan 2002 15:10
Well if you look at the duration and cam timing on the factory cams you will see the cam event timings are very near optimal. At least from the software I use.
The lift is not agressive but it doesnt need to be.
The zx12 has a big bore and big valves. More so than any other bike. So lift isnt going to gain much.
Maybe a more agressive opening ramp would yeld some power?
In any case I wouldnt think it would be cost affective.
I dont believe on a 1199 engine is is worth spending money on cams. An engine of 1300+ cc is another story thou.
Y2KZX12R
CompetitionCNC.com
justoyz2
Justoyz Racing
posted January 28, 2002 02:00 PM
Thanks for the info. just bouncing the cam questions around and it appears that nearly everyone is on the same sheet of music. I think I need to have mine degreed, because my bike is only making 164 with a a/f ratio of 13.2.
I am running it around 14.0 right now and making 168. I think I will have the degreeing done and go from there.
0.22570610046387 seconds processing time
