BIKELAND > FORUMS > ZX12R ZONE.com > Thread: bar grips NEW TOPIC NEW POLL POST REPLY
aliveagain
posted June 14, 2004 07:07 PM
bar grips
every time I use the canyon dancer tie down,it pulls the grip up the handlebar.What am I doing wrong or is this normal?I just find it a pain in the ass and worry about fucking up the throttle.
niuhi
posted June 14, 2004 09:30 PM
I'm not exactly sure which tie down your using, but perhaps this will help. Take a piece of nylon rope tie it's ends and make a loop. the loop when stretched between your fingers should go no farther than where your ties attach to your bars. Attach your ties to the bars, then one at a time, instead of running your ties to where they attach on the trailer (I'm assuming trailer) take the end and go through one end of the loop and THEN down to the attaching point. Do the same for the other side. this will keep the ties from sliding when tightened, yet allow them to snug up on the bars. Hopefully this is what you were referring to. Otherwise I'll just shut up.
Hawaii no ka 'oi
Les
wilson1
posted June 15, 2004 01:42 AM
i have the same problen with canyon dancer you are doing nothing wrong its just the way it is you might try changing the angle of the tie down straps i found this helps
posted June 15, 2004 06:00 AM
Use PVC over the grips with the canyon dancer. 1 3/4" if possible.
0.24393606185913 seconds processing time
