BIKELAND > FORUMS > ZX12R ZONE.com > Thread: wide band commander NEW TOPIC NEW POLL POST REPLY
rac4it
Bergie
posted June 02, 2004 04:36 AM
wide band commander
Have you guys seen this?
http://www.widebandcommander.com
YCIS what do you think?
canadamaxxer
posted June 02, 2004 04:50 AM
That is a crazy amount of cash ($529.00). It does a lot of things, but do we need all of that info?
Here is another alternative...it costs $78 US http://www.sdsefi.com/mmm.htm
bossman12r
posted June 02, 2004 06:04 AM
I best part is it records your A/F and with the pc3usb they are looking into hooking them together. If you drag race this is a great tool. When I can afford one I'll get it.
gen 4 zx10 is fast
your car is slow
Fuck Nitrous...Got Boost?
posted June 02, 2004 06:42 AM
Price is about right...most of that is in the sensor itself (probably 150+ or so..those things arent cheap).
I dont see anywhere that it controls the temperature of the sensor (although it is a heated sensor..just dunno if it controls the heat in the brain or not)...I would have to assume it does.
canada...that setup uses a narrowband 02 sensor...not even remotely close..or accurate.
Do not taunt happy fun ball!
deathpulse
posted June 02, 2004 07:49 AM
I'm so all over this if it automates a connection with the PCIIIr/PCIIIUSB. Damn - why would i need to take my bike to a DJ250 for a single map (for 300 bucks), when I can map my own dynamically, no matter what, any time! Sounds like a FANTASTIC deal if it works that way .
your car is slow
posted June 02, 2004 08:01 AM
I seriously doubt its going to reprogram your map for you on the fly.
bossman12r
posted June 02, 2004 08:07 AM
I know it sounds to good to be true but
The Wide Band Commander is a universal product, it can be used on anything from a lawn mower to a Viper. Since the kit requires that you weld a boss to the exhaust, the bike guys have been a little apprehensive to install this kit. It looks as if the aftermarket exhaust companies are actually including the 18mm x 1.5 threaded boss on some applications, that's a good thing. I doubt we'll ever have a plug and play scenario for your bike, but there is potential for communication between the WBC and a PC3 USB
gen 4 zx10 is fast
deathpulse
posted June 02, 2004 08:13 AM
hmm... I may not be a good "wrench" but I'm a HELL of a programmer - if there IS an interface from the WBC to the PCIII, maybe I can make a small proggie for, say a palm to auto update the map based on trigger input... I haven't really played with the palm interface to the PCIII in a while. Alternatively, a small footprint pc maybe.. hmm. Time will tell what options are available - please keep us posted on this!!!
your car is slow
posted June 02, 2004 08:29 AM
Oh I have no doubt itll generate some sort of output similar to your "map" that you can use to build your own "map"...thats gravy.
but making those adjustments for you..on the fly...well..that would be pretty impressive..and put alotta dyno tuning shops outta business.
Whimp
posted June 02, 2004 06:36 PM
Hardracing.com already has them down to around $469.00 While the unit doesn't tie-in with the powercommander, it has some neat features that could be handy for tuning or running. It has (as I understand) a memory of about 10 minutes that you can download to moniter your air/fuel mix. (beats the hell out of looking down at 140 MPH to see what going on!) Plus an output (2 Amp) that can be programed to fire NOS,or shift light,etc. For those of us who live out in the boonies, or can't afford a dyno for tuning, I think that this thing can give some "real world" info. I'll let you know, mines on order. Check-out the info on the web-site.
Tearinitup
VP Code Monkey
posted June 03, 2004 06:47 AM        Edited By: Tearinitup on 3 Jun 2004 07:48
I also am working on a software upgrade that allows 2 generic analog channels to be viewed and configured to display other channels (boost, temp, fuel pressure). The configurable outputs can then be hooked to one of these sensors instead of TP.
bossman12r
posted June 03, 2004 02:23 PM
Can it attivate NOS in any gear?
gen 4 zx10 is fast
vozizm
Got Nothing Witty To Say
posted June 10, 2004 07:33 AM
can it?
posted June 10, 2004 08:42 AM
With this item I can tune my own PC3 for optimum f/a ratio...Record the performance of the TPS, so I can adjust it for Max. Performance.......I Like being able to do it at home myself...
But I would still need a Dyno to tune the the ignition, Nitrous and Maximum HorsePower...Too bad they cant make some kind of portable Dyno for tunning HorsePower at home...
I think its a good tool though...
deathpulse
posted June 10, 2004 09:52 AM
Anyone know a really good DynoJet tuner in the northern New Jersey area? I really need a custom map already .
posted June 10, 2004 10:01 AM
I think Del's Performance is a good place. Ask Bill Koz..
deathpulse
posted June 10, 2004 10:54 AM
Hey Turbo - do you have the contact info for Del's Performance... can't seem to find it on Google..
D
posted June 10, 2004 12:10 PM
It's still an open loop system and will not adjust fueling.
The trick would be to have a system adjust the fuelling from this products readings (ie - closed loop)
posted June 10, 2004 04:12 PM
Dels Performance Cycles
50 East 17th Street
Paterson, NJ 07524
1-973-569-1111
Y2KZX12R
CompetitionCNC.com
posted June 12, 2004 05:34 PM        Edited By: Y2KZX12R on 12 Jun 2004 18:36
D, exactly. When the hell are these bike companies gonna put a real computer in these bikes.
We need a federal crackdown on exhaust emitions to force these manufacturers to put some kind of OBDII system on these bikes.
This is the software I use to tune my 02 ss camaro.
http://www.hptuners.com/products-edit.html
Y2KZX12R
CompetitionCNC.com
D
posted June 12, 2004 10:43 PM
I'm sure we'll see it in a few years although I'd imagine it'll be more like OBDIV/V.
posted June 12, 2004 11:09 PM
I would think one of the biggest challenges is the slew rate...C'mon, how many car engines do you know that idle at 1000rpm, and can rev to 12000 rpm in less than three seconds. A motorcycle engine's A/F ratio would change much faster than a car can, methinks.
Y2KZX12R
CompetitionCNC.com
posted June 13, 2004 05:17 AM
Swft, yea thats true. But the GM computers in the 02 cars are very fast. Way fast enough to cope. But the real bennifit would be the interpolation of maps.
WOT the pcm runs under different set of maps. So dragracers would work with VE tables. While road racers would work with MAF tables.
Basically timing calculated from a combination of several maps. As is the fuel. So tuning a turbo kit would be as simple as switching injectors adding a fuel pump with more volume and software changes.
Have you guys played with hondas closed loop systems on bikes at all?
I'll be willing to bet they are the first ones with a real closed loop system on the 1000.
This HP Tuners software really opens up the guts of the GM computers for all to see. I didnt think the system was as robust as it is.
I've worked with Several aftermarket systems like Motec etc. and they are very primitive compared to this GM PCM.
The Data logging feature is nice to watch and adj the long term and short turm fuel trims.
Come on Dynojet, how about a replacement computer for the bikes? !!!
Y2KZX12R
CompetitionCNC.com
D
posted June 13, 2004 08:50 PM
Too many variables between manufacturers for Dynojet to realistically come out with a system that woked correctly - not a hit on Dynojet.
Unless the manufacturers were to switch to a universal vendor for their fuel/timing and programming supplies then I don't see how they could tie in all the required info to make a closed loop system work correctly.
Having said that - this wideband commander looks (to me) like it is the second (Power Commander being the first) step needed for a closed loop system.
Real time analyzer would have to be next and software with it to adjust the Power Commander based off of Wideband Commander readings.
Or sumthin...
justoyz2
Justoyz Racing
posted June 14, 2004 07:02 PM
I would suggest using a three wire sensor vs the single wire senor. I spent 100 bucks on the a/f meter and 3 wire sensor. It worked very well. For all of you truly automated wanabes, the motorcycle industry will not start using that technology until Big brother mandates strong emissions. Cars are equiped with closed loops systems. They know how to manage the emission on the bikes quite well. So don't look real soon. The Muzzy MMs system has this capabilities, but who has 1k to spend on an ecu>
0.26160597801208 seconds processing time
