claude
posted April 23, 2004 06:23 AM
Lost HP with overfilled oil?
What's the story about the lost HP when you overfill the oil pan? I remember I read this a few years when the 12 was introduced but what's the conclusion now? Thanks!
ra12r
posted April 23, 2004 08:54 AM
It was a "normal variance" in the dyno. It did end up costing a few guys their bearings however......
deathpulse
posted April 23, 2004 09:33 AM
The deal is, put EXACTLY the amount of oil that is recommended by Kawi - no more no less. This sometimes puts the oil at a mid to low mark on the sight glass (when the bike is balanced PERFECTLY straight).
BA
posted April 23, 2004 04:48 PM
the bike is apparently a 'slow drainer', so, definitely put in the recommended amount.
If you were to keep adding oil all at once until it appeared in the window you'd end up overfilling.
claude
posted April 24, 2004 03:48 AM
Thanks guys. What I would like to know is more: was it true that more oil was taking out some HP or was it just a reason Kawasaki mentionned whne involved in the "Busa war"? How many HP (roughly) are lost; just a few (undetectable) or quite a lot? And is it still true (does
engine design changed over the years to avoid this)? Thanks again!
Ra12r
posted April 24, 2004 05:04 AM
It wasn't KMC it was Muzzy's that said "Less oil makes more HP"...... Like I said above, that statement cost alot of guys their bearings.
Less oil produces less windage, which according to Muzzy made more HP in there bikes or whatever their reasoning was at the time. However, I still stand by dyno variances for what ever difference they found and NEVER NEVER reduced the level of oil in my bike. I actually run my at the very top of the glass. When you start the bike you will quickly see that there is NOT ANY oil in the sight glass......... Do NOT play with "low oil level amounts" in your motor.
claude
posted April 24, 2004 08:48 AM
I don't own a 12 (only an old ZX-11) and that's why I ignore much about this. In a local discussion forum, a guy just got his ZX-12 out of his dealer for an oil change (among others) and he posted that his bike is now very low on power (he feel like ~50HP are missing). It probably is another reason that cause this but can the excess oil alone be the culprit?
Ra12r
posted April 25, 2004 04:52 AM
Normal dyno variance is not "50 HP".................. Oil is a lubricant not glue....duh! To lose 50 HP, they must have adjusted his cams wrong and then retarded the timing. Has your buddy gone to the track to see his MPH? That will be the best gauge.
your car is slow
Fuck Nitrous...Got Boost?
posted April 25, 2004 10:12 PM
hahaha...you could put 10 quarts in the bike and not lose 50hp...there is somethin else wrong there
Do not taunt happy fun ball!
posted April 25, 2004 10:25 PM
I lost 50hp when I mixed oil with my gas on my Zed X 12 (as those limeys say)
