BIKELAND > FORUMS > ZX12R ZONE.com > Thread: External Oil Cooler NEW TOPIC NEW POLL POST REPLY
ra12r
posted March 17, 2004 02:37 PM
External Oil Cooler
I have been pondering installing an oil cooler. Has anyone done this yet? I am trying to visualize where the return would go?
Marcos Peguero
posted March 17, 2004 03:10 PM
The bike has one already...
  Ignore this member    Click here to visit Marcos Peguero's homepage.
posted March 17, 2004 04:48 PM
I think he's looking for an finned cooler, like one for an auto tranny on a car.
ra12r
posted March 18, 2004 06:32 AM
Yeah Swift i was thinking about adding a finned cooler. Because the point was made about the oil temp in the motor helping to add to heat dispursement issues. How would I do this?!
psycho1122
posted March 18, 2004 06:34 AM
Run a Higher H2O content in your existing cooling system. Cooler running FI bikes make more power.
Marcos Peguero
posted March 18, 2004 09:48 AM
Make shure you use destilated H2O, no minerals.
ra12r
posted March 18, 2004 10:48 AM
Personally, I already tried running a H20/antifreeze mixture greater than 50/50 and that led to water boil and worse heat issues for ME! So I would like to add an external oil cooler(maybe) if that would help with some heat dispersement. I am trying to get all the difference that i can. Thanks
posted March 18, 2004 10:57 AM
You could purchase on of our oil filter re-locator kits and put a cooler in the line from the engine to the filter housing. But as everyone hinting, you don't need an additional cooler. Just put the right mix into your stock cooling system, properly bleed it and your stock cooler works VERY well.
Doug
psycho1122
posted March 19, 2004 05:41 AM
ra12r...What A/F Ratio's are you running? Lean engines run HOT!
I run a 1270 out here in AZ w/ no overheating issues.
addisonzx12
posted March 19, 2004 01:39 PM
I have noticed, on my bike(1380), once the oil gets really hot it stays hot. Long after the radiator temp comes back down to normal. I thought the lack of the external oil cooler was the main cause of the retained heat in the engine! I think an external cooler would help in cooling the engine(and clutch plates) back down. I never thought of the oil filter relocator angle though! I think I will try it this summer.
ra12r
posted March 20, 2004 12:37 PM
The motor doesn't run hot, it STAYS HOT. The motor actually runs between 8-9 oclock, but if you stop to get gas it is 11 to 12 oclock and flashing when you turn the key on. Then the bike is VERY HARD to start. So, I am thinking to improve the oil cooling system. My mix has been experimented with multiple combinations. 50/50 or 60/40 seems best water/coolant. I tried a coolant enhancer from Auto zone and it left a coat of white on the inside of all the passages. So I am NOT going to do that combo anymore. I didn't really notice much difference. I have also done some recent machining to the water passages, but I don't have the results yet.
So, "IF" someone was going to add an extra oil cooler, how would you do it???
posted March 20, 2004 01:34 PM
Easiest way I could think of would be to add the muzzy oil filter relocation kit, then plumb a cooler inline to the return line.
psycho1122
posted March 22, 2004 06:52 AM
ra12r....looks like you have a lean running engine. If your over 13.1, you will continue to have issues.
Ra12r
posted March 22, 2004 09:23 AM
Psycho, when i get it back together i am going to have the A/F checked.
psycho1122
posted May 21, 2004 05:44 AM
Looks like your cooling system is keeping up while it's running (flowing).
Cylinder temp looks to be Very high!
Have you checked A/F yet?
EastBayDave
posted May 21, 2004 03:39 PM
I bought a ZX11 oil cooler thru a salvage yard ($50), & it's been sitting on the bench forever as mine doesn't overheat...consistently 9-10 o'clock...
Fan runs sometimes on very hot days coming to stoplights, just as I come out of the twisties after riding hard. That Muzzy blade still puts out the big hot air blast out the side vents just like a champ!
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
0.26719903945923 seconds processing time
