BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Shift Light installation question NEW TOPIC NEW POLL POST REPLY
rotts4u
posted March 12, 2004 09:50 PM
I am installing one of those small little shift lights like shown here
http://www.second-look.com/html/shiftlight.html
And need to know what wire feeding into the back of the speedo/tach is the correct oneto use on an 03 ZX-12.
Someone said blue but there are several blues. One is light with some spots on it and at least one more is darker blue.
I prefer to get the tach lead up front because that is where I want to store the non-waterproof box. Can any one help me?
Don
vozizm
Got Nothing Witty To Say
posted March 13, 2004 05:42 AM
vozizm
posted March 13, 2004 05:51 AM
i installed a Harlan Shift Light!!
50 bucks... but im no wrench so i had issues... plus im hard headed!!!
http://www.zx-12r.org/phpBB2/viewtopic.php?t=13477
oldkawboy
posted March 13, 2004 06:23 AM
Don,
It's a solid light blue wire on my '00 model. I mounted my box in the trunk and tapped into the wire from the ECU but most people do what you're doing.
We all got off for Maxton and the reservations are made....are you and the 12 ready?
Dan
canadamaxxer
posted March 13, 2004 09:57 AM
I just installed my Harlan shift light on my '01, and found that I could not get the blue wire to work for me at all. I checked the manual and it stated that the blue wire is a square wave signal (digital). The Harlan light would not work with that digital siganl, so I connected it to the negative side of the #1 coil wiring and set the Harlan light to "coil per cylinder". It works like hot damn now.
The wierd thing about the square wave signal on the blue wire is that I have to question why Kawasaki went to the trouble of converting the pulsing DC signal from the coils to a digital square wave. It seems like more work to to that, but then again they would have to convert that signal to digital at some point in the circuit anyways, so why not in the ECU? It would simplify the "meter assembly", which of course reduces cost (for the manufacturer, anyway).
rotts4u
posted March 13, 2004 06:49 PM
Yes the 12 is ready and assuming some act of nature does not stop me I will be there. Shift light or not. That is mostly something I am trying to get put in for the article that will be done on the bike. Its a cool little unit.
I may even bring my new GSXR6000 too if I get enough miles on it before them
See ya there
Don
oldkawboy
posted March 15, 2004 06:22 AM
Don,
Can I make a pass on that GSXR6000? With a big bore kit like that, maybe I can run REALLY fast....LOL
Dan
rotts4u
posted March 22, 2004 06:30 PM
It seems the shift light I am using also needs the coil signal as it will not work on the blue wire. I will fix it after maxton is over.
I only got to ride the new 600 once so I will not be bringing it to MAxton.
Sorry but I missed the joke about the big bore kit. Can you explain?
don
BA
posted March 22, 2004 07:43 PM        Edited By: BA on 22 Mar 2004 19:43
He's punnin' on your typo of gsxr6000 vs gsxr600.
0.32264709472656 seconds processing time
