Staying true to the Internet rumors - Honda today announced the Spring 2010 release of their long-awaited VFR1200F. Stuffed full of technology, the new 1237cc V4 employs features such as fly-by wire throttle, combined anti-lock brakes, an available 6 speed tiptronic style dual clutch transmission, seamless fastener-less bodywork, sliding CV joint shaft drive and more. Price and further specs are TBD. Claimed curb weight for the fully automatic version is 613lbs, while the 6 speed manual slipper clutch equipped unit weighs 22lbs less.
Drawing from a longstanding legacy of innovation within Honda’s V-4 lineup, the 2010 VFR1200F embodies the new generation of V-4 technology and unsurpassed rider benefits, setting the stage for Honda’s next 50 years. Honda’s V-4 heritage and VFR tradition is fully realized in the VFR1200F. It has been re-created in astonishingly innovative form through the fusion of advanced technology imported from the MotoGP world and other cutting-edge environments. Net result: a futuristic sport motorcycle created for the sheer joy of riding, custom tailored for experienced hands who ride hard, ride long, ride far and ride often.
- Honda MotoGP V-4 engine technology and architecture bring cutting-edge performance to the VFR1200F.
- Unique cylinder layout with rear two cylinders located innermost on the crankshaft and front cylinders located outboard narrows the rider interface aboard the VFR1200F.
- Throttle By Wire for next-generation throttle response.
- Optional Dual Clutch Automatic Transmission with manual mode and automatic mode with two D/S modes and paddle-style shifters offers unparalleled freedom through innovative technology.
- Next-generation shaft drive system with offset pivot point and sliding constant-velocity joint for a new level of shaft-drive performance and control.
- Transferable one-year, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
Engine/Drivetrain
- Light and compact 1237cc liquid-cooled 76-degree V-4 pumps out amazing levels of power with a distinctive V-4 feel and sound.
- Symmetrically Coupled Phase-shift Crankshaft uses 28-degree crankpin offset to eliminate primary engine vibration.
- Asymmetrical exhaust lengths between front and rear cylinders boost power production and enhance power feel.
- Lightweight and compact Unicam® valvetrain allows for significantly smaller cylinder heads.
- Honda slipper clutch in manual-shift model allows unencumbered sport riding.
Chassis/Suspension
- GP technology layer-concept aero fairing for unrivaled air management.
- Honda Pro Arm® single-sided swingarm with single gas-charged shock delivers cutting-edge rear suspension action; features handy remote spring preload adjuster, rebound damping adjustability and 5.1 inches of travel.
- Stout, sport-oriented 43mm inverted cartridge fork with spring preload adjustability and 4.7 inches of travel.
- New controls with smoother and more precise tactile feel enhance the riding experience.
- New-technology seat construction permits a higher level of seat shaping and forming details.
- Saddlebag mounts come standard on both versions of the VFR1200F.
Model: VFR1200F / VFR1200F with Dual Clutch Automatic Transmission
Engine Type: 1237cc liquid-cooled 76° V-4
Bore and Stroke: 81mm x 60mm
Compression ratio: 12.0:1
Valve Train: SOHC; four valves per cylinder
Induction: PGM-FI with automatic enrichment circuit, 44mm throttle bodies and 12-hole injectors
Ignition: Digital transistorized with electronic advance
Transmission: Six-speed (VFR1200F) / Six-speed automatic with two modes and manual mode (VFR1200F with Dual Clutch Automatic Transmission)
Final Drive: Shaft
Front Suspension: 43mm cartridge fork with spring preload adjustability; 4.7 inches travel
Rear Suspension: Pro Arm single-side swingarm with Pro-Link® single gas-charged shock with remote spring preload adjustability and rebound damping adjustability; 5.1 inches travel
Front Brake: Dual full-floating 320mm discs with CBS six-piston calipers with ABS
Rear Brake: Single 276mm disc with CBS two-piston caliper with ABS
Front Tire: 120/70 ZR17 radial
Rear Tire: 190/55 ZR17 radial
Wheelbase: 60.8 inches (1545mm)
Rake (Caster angle): 25°30’
Trail: 101.0mm (4.0 inches)
Seat Height: 32.1 inches (815mm)
Fuel Capacity: 4.9 gallons
Color: Candy Red
Curb Weight*: 591 pounds (VFR1200F) / 613 pounds (VFR1200F with Dual Clutch Automatic Transmission)
Meets current CARB and EPA standards.
Specifications subject to change.
*Includes all standard equipment, required fluids and full tank of fuel--ready to ride.
