BIKELAND > FORUMS > ZX-14.com > Thread: digi kill 3 question NEW TOPIC NEW POLL POST REPLY
joel787
posted July 30, 2012 03:42 PM
So im having trouble shifting, been told i should add more kill time does each line on the dial equals 10mils? or how does it work, the way i have it my selenoid is not conected directly into the ram...is this a must?
posted July 30, 2012 03:43 PM
Better call Muzzys on that one .. I had 3 dig a kill boxes go bad ... I hate them damn things ..
joel787
posted July 30, 2012 03:48 PM
Hmm...u might be right on this one after a while ive found myself chopping the throttle so it could shift right...around 6k rpms it works but 10.5k or so it doesnt
Viper
posted July 30, 2012 03:58 PM
connect solenoid directly to the ram and rum the mps auto box
2012 ZX14R SE
kawasakijockey
posted July 30, 2012 05:36 PM
You must have used them before 08, Murray at Muzzys told me about those. Over 6000 shifts on mine.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
kawasakijockey
posted July 30, 2012 05:39 PM
The delay feature helps more than kill time in most instances. It allows the ram to move before the kill time is activated. You could have too much delay.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
joel787
posted July 30, 2012 05:43 PM
sorry I just don't quite understand the dials, can u break it down?
kawasakijockey
posted July 30, 2012 06:22 PM
Kill: The amount of time that fuel is cut off.
Delay: The amount of time allowed to the shift lever to move upward BEFORE "kill" cuts off fuel. It is simply delaying the fuel kill while the lever starts to move.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted July 30, 2012 06:59 PM        Edited By: smokinZX14 on 31 Jul 2012 03:02
I had 2 Dig a kill 2s and one of the new dig a kill 3s and they all took a shit .. Jesse had two of the dig a kill 3s go bad ..If you have one that works you are a lucky man .. Bad part Muzy did not stand behind them ... At least MPS has a life time free replacement for there kill boxes .. My last one was on my 2009 ZX14 , so it was after 08 .. I removed it and replace it with an MPS box ..
I will say when they are working the work great !
0.26262402534485 seconds processing time
