BIKELAND > FORUMS > ZX-14.com > Thread: GPR Steering damper questions NEW TOPIC NEW POLL POST REPLY
Thread: GPR Steering damper questions [ This thread is 2 pages long: 1  2     Next» ]
lowcel
Happy on 2 wheels.
posted May 31, 2008 10:08 AM
Does anyone have pictures of the GPR damper installed on their ZX14? Also, was it pretty easy to install? Last question, what size is the steering stem nut?
Thanks.
2007 Z14 SE - Yoshimura TRC full race exhaust w/ carbon can - PCiii w/ map from HPC - Flies removed - Pipercross air filter - Speedohealer - Puig Double Bubble - Fender Eliminator - GPR Steering Damper - Puig Frame Sliders - HID's - Halo's
slates
posted May 31, 2008 09:15 PM
http://www.bikeland.org/board/viewthread.php?FID=27&TID=38210&set_time=
lowcel, I don't remember the size of the stock steering stem nut, but I believe it's 32 or 34mm. I think what GPR gives you as a replacement nut is STD sizing. It was very easy to install. I had to borrow the socket to loosen the stock steering stem nut. Pics posted at url listed above.
lowcel
Happy on 2 wheels.
posted June 01, 2008 03:39 AM
Beautiful bike and thanks for the reply. I can't tell from the picture, does it just connect to the frame with the bolt used with the tank cover or do holes need to be drilled?
BobC
posted June 01, 2008 08:33 AM
I have ridden bikes that really need a steering damper but can I ask, seriously, do you need to fit one to a bike as stable as the 14 ?
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
lowcel
Happy on 2 wheels.
posted June 01, 2008 10:48 AM
I would rather have it and not need it than to need it and not have it. To me the relatively low cost of a steering damper isn't worth dying over in case I do need it some day.
shane661
posted June 01, 2008 03:16 PM
For any hard riding I would recommend it. In fact, many LSR venues require it. I agree that it is a very stable machine in stock form. But it is not nearly as stable a it will be with a good damper.
Like has been said here before, "you don't need it until you need it....and then you REALLY need it!."
slates
posted June 02, 2008 05:05 AM
Beautiful bike and thanks for the reply. I can't tell from the picture, does it just connect to the frame with the bolt used with the tank cover or do holes need to be drilled?[/quote
Lowcel,
The frame doesn't need to be drilled. It mounts to the center nut location at the cover in front of the gas tank just behind the steering stem nut. There are two "set" screws that snug down to the frame and use RED Loctite to secure.
shane661
posted June 02, 2008 05:17 PM
Slates, any leaks from the GPR?
lowcel
Happy on 2 wheels.
posted June 02, 2008 05:57 PM
Thanks for all the help. I ordered one today, the non-V4 version though. With the money I saved I ordered some Puig sliders.
slates
posted June 03, 2008 05:09 AM
No...there better not be or I'll be seeking a full refund. Mine was done wiht a group that was going to the Corona Extra Honda Team...hence the gold dials.
Shogun
posted June 03, 2008 06:15 AM
My V4 started leaking after about 3 months of use. Returned to GPR for seal replacement...no charge and quick turn-around.
Not happy that it failed so soon but their responsiveness was good.
Shogun
06 ZX14 - Arata exhaust, PC III, McIntosh Ext swingarm, Vortex lowering links, Racetech rear shock, Marc wheels, To be continued...
lowcel
Happy on 2 wheels.
posted June 10, 2008 05:24 PM
Received the steering damper and got it installed. Took about ten whole minutes.
SLVR_BLT
Chicken Strips!
posted March 29, 2010 06:56 PM
I think it was a 32mm, or you can use a 1-1/4" socket which is what i used. It was on pretty tight so make sure you hold the bike tight and use a long breaker bar.
SLVR_BLT
Chicken Strips!
posted March 29, 2010 06:59 PM
Its actually quite shocking how a machine with such a steep rake is so stable in factory form. 23.5 deg rake is pretty darn steep for any bike, let alone one with a near 50:50 weight dist. My gixxer 750 doesn't even have a rake that steep and that mofo gets squirrelly sometimes wheeling it around the canyons.
lowcel
Happy on 2 wheels.
posted March 29, 2010 07:04 PM
I appreciate the advice but I got rid of my ZX14 about a year ago. I decided to try out a different type bike.
zixxer14
Damn that was Quick
posted March 29, 2010 08:23 PM
Wow a Harley!
lowcel
Happy on 2 wheels.
posted March 29, 2010 08:24 PM        Edited By: lowcel on 30 Mar 2010 03:26
Wow a Harley!
Nope, mine is a 2007 (I purchased it new as a left over), it was produced before Harley acquired MV Agusta.
SLVR_BLT
Chicken Strips!
posted March 29, 2010 08:28 PM
Wow a Harley!
That's a fine piece of machinery there bud.
lowcel
Happy on 2 wheels.
posted March 29, 2010 08:31 PM
Wow a Harley!
Thank you, I certainly enjoy it. There are some things about it that I like better than the 14, some aspects of the 14 I liked better than the MV Agusta. I still believe that the 14 is a truly awesome piece of machinery, it just wasn't exactly what I wanted.
68gts2
hobbies ( Beating you !!! )
posted March 30, 2010 07:38 AM
Is it hard to get to the key in with that big dude mounted on the steering head?
zx14fan
posted March 30, 2010 09:49 AM
How much did you pay for that damper?? Looks good
epd345
posted March 30, 2010 04:42 PM
The GPR V4 is the later version of the one pictured above and it seems to be smaller. I have the V4 and its been great, No key interference at all.
epd345
posted March 30, 2010 04:46 PM
Heres a pic of the GPR V4
SLVR_BLT
Chicken Strips!
posted March 30, 2010 05:30 PM
You didn't install the other 2 screws to the frame? I had to drill 2 holes for my Scotts damper to ensure its sturdy.
epd345
posted March 30, 2010 05:38 PM
GPR does not come with or require that you drill holes in the frame, mount seems plenty solid
All times are PST(US) [ This thread is 2 pages long: 1  2     Next» ] < Previous Thread     Next Thread >
Quick Reply:
0.305756807327 seconds processing time
