0312R
posted May 07, 2010 01:46 PM
Gotta have mods
I have had my 03 ZX12R for about 4 years now and I would like to do a few mods to it to add some more power but more importantly, smooth it out.
So far I have a scorpion slip on which I'm going to get rid of for either an Akrapovic or Muzzy full exhaust. But right now with the slip on, the bike seems to run alittle rich. At least that's how it smells. Would adding a PCIII and getting the appropriate map help with this? I have also heard certain maps can help with how jerky and un-smooth it is. Is this true?
Also it seems to be sluggish off idle. If I have it idling around 1000 rpm and go to rev it quickly it chokes quickly then revs up. Is this a good idle rpm?
Any other gotta do mods that you can think of would be great. Sprockets for street riding, filters, anything that doesn't cost thousands. I'm a power junkie lol
Right now I'm going to do the obvious power mod..... a tune up. It has 10k on it and I'm sure the plugs are the originals. Can anyone suggest a plug?
Thanks a lot.
supra5677
posted May 08, 2010 07:30 AM
the stock zx12r spark plugs work fine. They should be ok at only 10,000 miles. I had both the akrapovic and the muzzys on my 02, I liked the performance of the akrapovic better. Now I'm running dual exhaust. You can also try a K&N or BMC race filter.
supra
badass12
posted May 08, 2010 05:15 PM
That email is hdailey1@cablespeed.com.
psycho1122
posted May 09, 2010 04:55 AM
Stock Plug works great.
Off Idle issue? I would check and adjust the air screws on the TB's. Make sure they are even to start. With a full pipe, have them open at least 2 full turns. Use a manometer (carb stick) to open the screws up from there, making sure all 4 holes are pulling even.
BMC Race filters provide the most flow w/o dirt in the airbox.
Seal all the leaks in the ram-air = FREE HIGH SPEED POWER.
PCIII will always help the overall powerband, especially with a pipe.
Muzzy pipes make the most "Power Under Peak". You do not always ride around at redline.
Megabyte
posted May 09, 2010 08:55 AM
quote: the stock zx12r spark plugs work fine. They should be ok at only 10,000 miles. I had both the akrapovic and the muzzys on my 02, I liked the performance of the akrapovic better. Now I'm running dual exhaust. You can also try a K&N or BMC race filter.
supra
Which dual exhaust are you running?
0312R
posted May 09, 2010 10:39 AM
Ok cool. Ill get some factory plugs and start looking for a full muzzy system.
0312R
posted May 09, 2010 12:39 PM
Also, here is a picture I took the other day if anyone is interested.
0312R
posted May 15, 2010 09:30 AM
From what I have been reading... its a good idea to go -1 on he front sprocket? For street riding?
psycho1122
posted May 16, 2010 04:43 AM
It will get you to 190 mph a bit quicker if you are running a fresh 190 rear tire.
0312R
posted May 16, 2010 07:38 AM
im running a bran new avon 200. So it will help a bit in the acceleration department. I dont plan on going 190 mph too often lol Is it worth it on the street?
psycho1122
posted May 17, 2010 04:09 AM
quote: im running a bran new avon 200. So it will help a bit in the acceleration department. I dont plan on going 190 mph too often lol Is it worth it on the street?
-1 Down? Hell yeah, It's fine.
NINJA12
posted May 17, 2010 07:37 AM
The Akrapovic gives the bike much smoother manners than the Muzzy.
The muzzy is a very free flowing pipe and you feel it in the bars and pegs.
Many people also have tuning problems with a low end stumble thats hard to cure.
AKRAP++++++++
0312R
posted May 17, 2010 08:23 AM
Well right now I'm not liking how unsmooth the bike is down low and all it has is a Scorpion slip-on. Its jerky coming out of turns and I try to be as smooth on the throttle as possible. So I don't think the Muzzy system is gonna please me. So I guess im gonna have to spend the dough and get a Akrapovic system.
Thanks for all of the help
