Kawasaki H2 Ninja Forum
BIKELAND > FORUMS > H2 NINJA.com > Thread: H2 numbers NEW TOPIC NEW POLL POST REPLY
burn
posted November 29, 2014 03:43 PM
H2 numbers
http://www.visordown.com/motorcycle-top-10s/top-10-most-powerful-bikes-of-2015-so-far/25953.html
Interesting numbers
burn
TNCHIP
posted November 29, 2014 05:56 PM
What numbers bother you ?
It will be the most powerful street bike by a good margin
TNCHIP
burn
posted November 29, 2014 10:33 PM
The numbers don't bother me just was hoping once it was on a dyno it would make more than
advertised. I know where it should shine is the torque, just thought it would make more hp than
my 14R with all the hype kawi has put out. built beyond belief
burn
posted November 30, 2014 09:23 AM
The numbers need context. Let's see power curves first.
posted November 30, 2014 09:41 AM
Btw, links:
On-road
epa.gov/oms/cert/documents/cert-tst/15-mc-ctrr.xls
Off-road
epa.gov/oms/cert/documents/cert-tst/15-ofmc-atv-utv.xls
posted November 30, 2014 11:59 AM
147 KW = 197.130 horsepower
posted November 30, 2014 06:35 PM        Edited By: swft on 1 Dec 2014 02:49
And the article is somewhat misleading. The EPA does not cerifty engine output, it certifies that the engine meets emission regulations. The rated power outputs are supplied from the manufacturer.
to wit:
EPA's engine and vehicle compliance information system, Verify, collects emissions and fuel economy compliance information for all types of engines, vehicles, and equipment used in transportation and other mobile source applications. The Verify information system is used by engine and vehicle manufacturers to report this information to EPA.
posted November 30, 2014 07:09 PM
So in actuality, the EPA doesn't test anything, instead the manufacturer tests and reports to the EPA:
http://www.epa.gov/otaq/regs/roadbike/23-hmc-reviewsheet.pdf
burn
posted November 30, 2014 07:12 PM
Your right there not certifying engine output just showing how much horsepower they made on there dyno
burn
posted December 01, 2014 06:05 AM
Nope...the point is that the EPA gets *all* that info from the manufacturer
burn
posted December 01, 2014 06:21 AM
While every dyno is different, the EPA lays down extensive specifications for the calibration of dynos, right down to the ambient air pressure during tests, to make sure its figures are comparable. Of course, the EPA is concerned about pollution, not performance, but to complete the emissions tests the bikes must hit a ‘rated’ peak power figure on the dyno, and that number is included along with all the other details right down to the VIN of the bike used for the test procedure.
Your saying the EPA doesn't test the bikes on a dyno while doing emission testing?
If that's true the article IS very misleading
Where did the EPA get the 207.9bhp figure when Kawasaki claims 197 for the ZX-14R?
burn
posted December 01, 2014 06:44 AM
The EPA gets all the info from the manufacturer. They provide a standardized testing methodology and are tasked with *enforcement* only, not testing and verification.
So there's no EPA dyno shop anywhere...If the manufacturer wants to sell the bike in the US, they have to test using the prescribed methodology and standards, then report the results to the EPA. *IF* the EPA suspects or is informed of false data, then they will act (Wire Fraud, etc.)
Example: http://www2.epa.gov/enforcement/2015-clean-air-act-vehicle-and-engine-enforcement-case-resolutions
posted December 01, 2014 06:45 AM
And sorry if I'm derailing the thread a bit! Just wanted to make it clear that those numbers are given to the EPA from Kawasaki.
posted December 01, 2014 07:30 PM
Zactly right.I studied all that pretty thoroughly when we built the Muzzy Raptors.
posted December 01, 2014 08:05 PM
Salad days
fullzx12r
French Guy
posted December 07, 2014 01:34 AM
zx-12r 01'
zzr 1400 06'
hayabusa 08'
zzr 1400 12'
0.22750997543335 seconds processing time
