2009 VMAX YAMAHA
BIKELAND > FORUMS > VMAX-ZONE.com > Thread: Can anyone help with a XV110 Virago NEW TOPIC POST REPLY
Obba
posted February 21, 2010 11:55 PM
Hi all,
I normally spend my time in the ZX14 section - so be nice to me ok
I have a mate who has a 1993 XV1100 Virago 29k-kms.
His front cylinder is running very sooty. He has recently replaced his air filter and suspects he didn't fit the rubber pipe back onto the frame air hole and can't work out if the problem started then or after.
He was advised to change his R7 plugs to a normal 6 and put some anti moisture additive in the fuel as he doesn't ride it often - like 500km per year.
He just has it as an emergency low maintenance transport backup.
Both his R7 and the 6 (after a 100km run), is very black and sooty on the front cyl. As the carbies have a fixed fuel mixture that can't be adjusted does anyone have any ideas?
The rear plug is fine, as the R7 and the 6 (which is running hot as to be expected).
The R is for Resistor.
The local bike shop, is now trying to get him to put it in for a carbie service and he was told it was going to be about 5hours work at $90ph... and he's on the rock & roll...
Just seems strange to be the front cyl and seems to have 'sort of happened' around the air filter replacement.
Thanks.
0.25866603851318 seconds processing time
