BIKELAND > FORUMS > 250R NINJA.com > Thread: NINJA 250 RECALL INFO NEW TOPIC POST REPLY
posted December 11, 2009 10:43 PM
Vehicle Make / Model: Model Year(s):
KAWASAKI / EX250 2009-2010
Manufacturer: KAWASAKI MOTORS CORP., U.S.A. Mfr's Report Date: NOV 24, 2009
NHTSA CAMPAIGN ID Number: 09V464000
N/A
NHTSA Action Number: N/A
Component: ENGINE AND ENGINE COOLING
Potential Number of Units Affected: 259
Summary:
KAWASAKI IS RECALLING MODEL YEAR 2009-2010 EX250 NINJA 250 MOTORCYCLES. POROSITY IN THE ENGINE CASE COULD ALLOW ENGINE OIL TO LEAK, AND BE DEPOSITED ON THE REAR TIRE. A SMALL NUMBER OF UPPER ENGINE CASES FOR THE AFFECTED MODEL COULD HAVE POROSITY IN THE ALUMINUM CASTING. THIS POROSITY OCCURS IN THE VICINITY OF A PRESSURIZED OIL PASSAGE JUST ABOVE THE TRANSMISSION OUTPUT SHAFT.
Consequence:
ENGINE OIL LEAKING FROM THIS LOCATION CAN BE DEPOSITED ON THE REAR TIRE, CREATING THE RISK OF A CRASH.
Remedy:
DEALERS WILL INSPECT AND CHECK FOR LEAKS IN THE VICINITY OF THE SUSPECTED POROSITY. UNITS EVIDENCING SIGNS OF LEAKAGE WILL BE REPAIRED FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR ABOUT DECEMBER 8, 2009. OWNERS MAY CONTACT KAWASAKI AT 1-866-802-9381.
Notes:
OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
0.2281231880188 seconds processing time
