BIKELAND > FORUMS > ZX6R ZONE.com > Thread: FI light flashing 2008 ZX6R NEW TOPIC NEW POLL POST REPLY
suzukidude87
posted December 29, 2011 05:47 PM
Hello all, what could cause the fuel injection light to flash at all times, also bike Idles high. its all stock.
thanks GOD for blessing us with bikes!
Greenisbest
posted January 11, 2012 11:38 AM
What is the Fi code ?
END OF MESSAGE !
suzukidude87
posted January 13, 2012 01:26 PM
any way I can check that or is it something a dealer would need to check?
Greenisbest
posted January 14, 2012 07:39 AM
You can chewck the codes yourself.
Turn the ignition switch ON.
Push the MODE button [A] to display the odometer. Immobilizer Models
Then push the Mode button and hold it for more than 2 seconds and the Code if any will be displayed on the clocks
END OF MESSAGE !
suzukidude87
posted February 13, 2012 03:16 PM
thanks for the help I had a mechanic look it over, turns out there was a broken wire that goes to the servo motor on the throttle bodies, so after replacing the throttle bodies 2 times, he omed the wires that run to the survo and found the break.
0.37829494476318 seconds processing time
