BIKELAND > FORUMS > ZX6R ZONE.com > Thread: 00 zx6r new owner need help NEW TOPIC NEW POLL POST REPLY
pitbullrex
posted May 17, 2008 06:25 PM
hi guys i am newbie just recently got this ninja and now it has power but it wont start at all i went through all the trouble shooting charge battery, check fuses even the one under the starter, put a screwdriver to the starter and it cranks but wont turn over any help will be helpful
Sticks_n_Stones
posted May 20, 2008 12:45 PM
take it out of gear or put the kickstand up. Seriously, thats a very common mistake.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
thekaz
spell chequer is bustimicated
posted May 20, 2008 01:25 PM
Year ?
Battery voltage is XXX . X Volts ?
When the key is turned on do the guages check themselves ?
When the key is turned on does the oil light remain lite ?
If it has an "FI" light does it light up with the key on or does it flash ?
When the key is turned on does the neutral light come on ?
Is the handle bar engine kill switch in the run position ?
Will the bike "bump" start and run ?
there is more but start with these
D
posted May 20, 2008 07:54 PM
Engine kill switch
Sticks_n_Stones
posted May 21, 2008 05:28 AM
Yeah there is quite a few scenarios, but always start with the simplest. Because there is probably not a single veteran rider here who can say they have never been at least temporarily dumbfounded when there bike doesnt start when it should, only to find out it was something simple like a kickstand down while in gear or kill switch accidentally flipped.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
maximus
posted May 21, 2008 05:19 PM
Year ?
he is right,
does it crank on its own? is there spark? compression? Fuel? No crank?
posted May 23, 2008 09:55 PM
bacon?
pitbullrex
posted May 24, 2008 07:28 AM
no but if i do the screwdriver trick it will start
thekaz
posted May 24, 2008 11:09 AM
If it starts and runs via bump starting or jumping the starter motor then you have a start circuit problem.
Haveing a manual with a wiring diagram would HUGE here
BUT basically you need to electrically check everything as there are several parts in the start circuit that can go wrong. The side stand and the clutch lever switches are extremely common failures.
Without a wiring diagram I am just thinking out loud :P
If you were in BC I would just ride over there fix it then take ALL your beer :P
pitbullrex
posted May 24, 2008 08:09 PM
thanks
0.25816988945007 seconds processing time
