Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: Pulling both wheels off NEW TOPIC NEW POLL POST REPLY
DB
posted May 03, 2010 12:15 PM
The pitbull stands say not to use a front stand without using a rear stand. How does everyone pull off their rims? Using a front stand and the center stand?? Or how??
Thanks!!
Dan
04 ZX10r (Track only)
08 Concours14
posted May 04, 2010 08:24 PM
for the connie I haven't found a way to remove both wheels at once. if you have the back on centerstand and hit the front with a race stand you'll knock it over.
I'll have a way soon, for now i'm liking this bike for a SIMPLE way to take both wheels off
DB
posted May 05, 2010 02:25 PM
Thanks Steve!! So no one has pulled their front wheel off their Concours14 yet?? That's hard to belive!!
Dan
08 Concours14
TedG
posted May 06, 2010 12:04 PM        Edited By: TedG on 6 May 2010 20:08
I have pulled both wheels off on the Concours. While on the center stand the weight is biased forward. Just put a milk crate under the forks after removing the front wheel. Then you can remove the other wheel. It has been this way since the center stand was created.
Pit bull probably wants the rear stand to help keep it from tipping, and to sell two stands. They are not thinking of a bike with a center stand.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
posted May 06, 2010 09:16 PM
PIT BULL never went after our connie business. and DB, I've pulled the front wheel off mine, just not at the same time as the back.
I had to put real tires on my connie. and man I've been slinging it around the turns. I'm 3500 miles into a trip and nowhere near Tampa (home)
DB
posted May 07, 2010 11:29 AM
So what you do to get the front off alone??
Dan
08 Concours14
oncourse
I hate flies!!!
posted May 07, 2010 04:49 PM
Put it on the centerstand and place a 50 lb. weight of some sort on the pass seat. should work, if not add more weight...
Rob
2003 kx 500 SOLD
0.42746496200562 seconds processing time
