Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: Ted, how's the 09 ABS working for you now? NEW TOPIC NEW POLL POST REPLY
The Pope
posted March 27, 2009 02:36 AM
When you first got the 09, you were having some rider issues with the ABS kicking in too soon for your riding style. Have you resolved this issue?
The Pope
COG's NCAAD
TedG
posted March 27, 2009 07:04 PM
Well there is no resolution for it. It is mostly getting used to it. I slide the rear wheel, downshift hard, brake hard. All those things will get the ABS going and once you get used to it, things aren't so bad. Great no, but not so bad.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
The Pope
posted March 29, 2009 10:19 AM
Good to hear that it's something that you can live with.
It would be nice if there were a way to adjust the engagement point of the ABS system. (Please let me know if I'm mistaken about this!)
The Pope
COG's NCAAD
oncourse
I hate flies!!!
posted March 29, 2009 01:34 PM
Ted, do you have more confidence in the abs that your '08? I am used to regular brakes, abs takes your control away from you. Yes it can help, and yes it can hurt, just depends on the situation.
Rob
2003 kx 500 SOLD
TedG
posted March 29, 2009 08:29 PM
Rob
Confidence.....hmmmm. I have no lack of confidence because I never ride at over 70% of my ability. It is more of a distraction. I went for a 350 mile ride Saturday and the rear ABS went off at least 60-70 times. It goes off a lot when I downshift. The good part is that it seldom goes off when you go into corners at 80+. The front ABS has yet to go off. The weight of the bike must really make that front end stick ot maybe the front ABS is not as sensitive.
Thinking of confidence while writing this, I think it is fun when the bike does weird stuff. Saturday I was driving around a car and I lofted the front wheel and had to lean over while the front end was still airborne, it gave a good wiggle when it touched down as I was shifting into second and all I could do was smile and gas it. I wanted to do that again. So when the ABS goes off it is sometimes fun, sometimes annoying, sometimes distracting, and sometimes (more and more) a non event.
But with all that being said, I may try to do something to lessen the effect. Maybe with another line form the MC to the caliper or a valve restrict the ABS, I don't know yet. I do know this, under normal circumstances (not cooking it into a corner) It seldom goes off.
Ted
The fast color!!
Green 2005 ZX10R
The Pope
posted April 09, 2009 04:04 AM
Ted,
Have you looked at the thread titled "ABS Switch in the works or DIY solution?" on the other site?
It's given me some ideas on how the ABS can possibly be disabled when your only using the rear brake. (I persume you issue with the ABS is when your trail braking (rear brake only))
The Pope
COG's NCAAD
TedG
posted April 09, 2009 06:59 AM
No, I haven't but I most certainly will look.
Ted
The fast color!!
Green 2005 ZX10R
TedG
posted April 09, 2009 08:33 PM
I read it and I have a thought, it might not kick in so soon if the rear brake light switch was disconnected from the ABS because it usually kicks in if I am using the rear only or rear first (unless I unload the rear). Then just hook up the tail light to the switch and diode isolate it from the ABS and make it so I can switch it on and off. Easy to test all I need to do is disconnect the switch. Then if that works I can add some historisis (delay the signal to the ABS unit) and all would be good. Hmmmm I like that one that way the ABS is intact but only slightly delayed.
Ted
The fast color!!
Green 2005 ZX10R
oncourse
I hate flies!!!
posted April 10, 2009 02:24 AM
Just remember that both brake light switches are in parallel and either on can turn on the abs for both wheels, however abs will not kick in unless there is hydraulic pressure and slippage at the wheel. So if you have some front brake applied (brake light activated) rear abs should still work the way it does now.
Something to think about..
Rob
2003 kx 500 SOLD
TedG
posted April 10, 2009 07:09 AM
That is why I was thinking of separating it from the parallel hookup, I would diode isolate it. It may be the trigger, it may not, only one way to find out.
Ted
The fast color!!
Green 2005 ZX10R
The Pope
posted April 10, 2009 12:20 PM
My idea was to try and use a second brake pressuer switch (normaly open) or a relay in the front brake system. Remove the fuse for the ABS system, then wire this switch or relay with an inline fuse back to where the ABS fuse was. With this type of circuit, the ABS system would be in a deactivated state until you were using the front brakes.
Now I don't know if the ABS system will or will not reactivate if set-up this way. So someone would need to test this to see IF it would work.
The Pope
COG's NCAAD
BIKELAND > FORUMS > CONCOURS14.com > Thread: Ted, how\'s the 09 ABS working for you now? NEW TOPIC NEW POLL POST REPLY
0.35197710990906 seconds processing time
