Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: Area P muffler to Saddlebag Clearance? NEW TOPIC NEW POLL POST REPLY
drewherc130
posted August 11, 2008 10:15 AM
Hey all you Area P guys. How much clearance do you have between your bags and the muffler?
I just put mine on this weekend and I'm less than 1/4". I put the heat tape on the bag that came with the pipe. The instructions recommended 1/2" minimum clearance. Is that possible? Do I just need to do some fine adjusting of the clamps and angles?
Other than that, I love the set up though. Got my flies out, PC3 and Area P installed and the bitch hauls ass!
Thanks guys!
Drew
2008 C14, flies out, Area P-Carbon, BMC, PC3, Spencer Seat Mod, Alaska Leather, Helibars with Ram GPS mount, Nuvi 250W
"Life moves pretty quick. If you don't stop and look around once in a while, you could miss it."
wormgear
posted August 12, 2008 06:36 AM
They give you heat tape with the Area P now?
I managed to get close to ½” at first on mine, though I thought I never would. 17K miles later the clearance is about 3/8” and I’ve had no issues and no tape.
GodDamnit there's always such a big temptation to be good, to be good! (Tom Waits)
Phytrax
posted August 12, 2008 02:09 PM
Mine is pretty tight. I'd say 1/4", haven't seen any heat issues. Might take a closer look when I get home.
KX450F - kickstand
>>> MySpace --CLICK-- <<<
oncourse
I hate flies!!!
posted August 12, 2008 02:38 PM        Edited By: oncourse on 12 Aug 2008 15:41
Wish I could help, think my 2 bros oval has at least 1/2", guess you might need the tape?
Rob
2003 kx 500 SOLD
MasterBlaster
posted August 13, 2008 03:22 PM
Just put a set of Scorpion C/F Ovals on mine. they were a killer deal, less than 400 bux shipped. They were for the ZX14, but I had already put the ZX header on the Concours, and it was basically bolt up. Plenty of clearance and they match the bag angle exactly. They look factory and the C14 should have came like this. Sounds low and wicked, but not loud. Pics to follow in a couple.
limey Hooligan
US/British/Canadian. Not easy!
posted August 13, 2008 07:28 PM
MasterBlaster,
Did you have to replace the center stand after putting on a the ZX 4-2 system? Looks like you do if you install the dual system for the C14 that Muzzys sells....
Oh, and.....
Who runs Bartertown?
'08 Concours14 ABS
'01 ZRX1200R - Sold
'80 KZ1000 - Sold
wormgear
posted August 13, 2008 08:05 PM
MasterBlaster runs Bartertown.
Ya better know it.
drewherc130
posted August 14, 2008 12:13 AM
WG,
Yeah they supply two 2"x6" ish pieces of heat tape with the pipe. It's enough to run a strip the length of the bag.
drewherc130
posted August 21, 2008 12:24 AM
With a little adjusting, I was able to get close to 3/8" and it should be fine now.
Danny c
posted September 27, 2008 08:51 AM
I have about half inch. Have not noticed excessive heat. According to areap the carbon runs much cooler and they are right because I can touch mine on a hot day after a long ride.
danny c
K Bryant
Sponsor
posted October 02, 2008 08:50 AM
After extensive testing, we've updated our instructions to note "1/8" - 1/4" is fine for those installs that cannot obtain more clearance. We've continually tested on the dyno with mufflers actually touching the underside of the bag for a worst case scenerio with no issues, and minimal heat transfer. When there is a minimum gap of at least 1/8", it is a non-issue. As added precaution, we now include the adhesive backed heat tile in the hardware kits.
0.28041505813599 seconds processing time
