Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: engine and final drive changeout AMSOIL NEW TOPIC NEW POLL POST REPLY
cransell
posted June 13, 2008 09:36 AM
So I've heard good things about amsoils 10/40 synthetic..considerable reduction of engine heat. I also order the universal synthetic marine gear lube which is suppose to be an awesome product although pricey. I'll give an update after change, I'm only 2,900 miles in but ready for swap. Any of you guys used this stuff???
Chris Ansell
wormgear
posted June 13, 2008 02:00 PM
I use amsoil 10w40 synthetic motorcycle oil and amsoil severe gear 75w90 in the final. Don't know about the marine gear lube. You sure about it?
GodDamnit there's always such a big temptation to be good, to be good! (Tom Waits)
JamminJere
posted June 14, 2008 04:13 PM
I use the same amsoil as wormgear, I have since 1981... I've never used their Marine gear lube in a bike tho.. cant help you there
Jerry
There really isn't much difference between "the masses" and "them asses".
idphillips
posted June 17, 2008 02:34 AM
I've used their synthetic motor oil in my previous bikes and plan on changing to it on the C14 at the next oil change. It works great and their was definitely a noticable reduction on engine heat on the other bikes. I don't know anything about their marine oil though. Since they make a severe gear oil, that would be my choice over trying something for a use it wasn't specifically designed for. Just my two cents ...
cransell
posted June 17, 2008 07:24 AM
Yep, better just go with severe gear. Thanks, fellas
Chris Ansell
roadracer98
posted June 20, 2008 04:11 PM
I run the Motorcycle 10-40 in the engine and the Marine gear lube 75-90 in the rear diff.
Its real good stuff. Severe gear is great too, but its a bit overkill IMO for a MC diff. I run the Severe gear in my truck diff..
0.23607301712036 seconds processing time
